Loud rattle, except in overdrive
Old Aug 17, 2009 | 06:29 PM
Montano1's Avatar
Montano1
I have a noticeable rattle at all times except when the truck shifts into O/D. It rattles in P/R/N and 1/2/3. What could this rattle be ? I'm assuming the transmission because once it shifts into 4th it's as quiet as can be. But some other thoughts are the flexplate or the torque converter.
It's a '99 F350 CC LB DRW with 84K miles.
Old Aug 17, 2009 | 06:33 PM
nissandoc's Avatar
nissandoc
I'm pretty sure a lot of the 99's had this problem and it comes from the torque converter. I'm sure the 99 owners will chime in.
Old Aug 17, 2009 | 07:03 PM
zx250's Avatar
zx250
Of the next Riffraff East
Yep, sounds like marbles in a tin can? Mine was loud enough I changed it out just to get rid of the noise. Some say it's not a problem, others say it a sure sign of impending doom.
Old Aug 17, 2009 | 07:21 PM
Montano1's Avatar
Montano1
Just like marbles in a tin can. I guess they won't swap it out under warranty until it fails, right ? Why does the noise stop once it shifts into O/D ?
Old Aug 17, 2009 | 07:28 PM
zx250's Avatar
zx250
Are you less than 100K? If so, they might.
Old Aug 17, 2009 | 07:30 PM
61 uni's Avatar
61 uni
If it's like marbles in a tin can, you may want to replace it before it takes your tranny with it.
Old Aug 17, 2009 | 07:40 PM
zx250's Avatar
zx250
That was my reasoning for replacing mine. TCs are way cheaper that the whole tranny.
Old Aug 17, 2009 | 07:50 PM
hucka1a's Avatar
hucka1a
Mine is the same way. I called Brian at BTS. He said that it is very common for the torque converters on 99's to rattle until they lock. He also said that there is nothing to worry about.
Old Aug 17, 2009 | 07:53 PM
zx250's Avatar
zx250
You right Huck, and I lived and towed with mine for a while, but until I replaced it, I never knew how load it had gotten. I was afraid that something rattling that loud was bound to break.
Old Aug 17, 2009 | 08:01 PM
Montano1's Avatar
Montano1
I have 2 years left on the warranty so I'll just keep my eye on it for now.
Old Aug 17, 2009 | 08:04 PM
61 uni's Avatar
61 uni
What kind of warrenty do you have that is still good?
Old Aug 17, 2009 | 08:08 PM
zx250's Avatar
zx250
You can find a tranny shop that will say it's about ready to fly apart and see if your warranty will fix it now.
Old Aug 17, 2009 | 08:14 PM
hucka1a's Avatar
hucka1a
I would love to replace mine. It's annoying and embarrassing. It's just not in the cards yet.
Old Aug 17, 2009 | 08:17 PM
Montano1's Avatar
Montano1
I just bought the truck from my local Ford dealer, and I opted for the 2 year warranty.
Old Aug 17, 2009 | 08:23 PM
hucka1a's Avatar
hucka1a
If thats the case, they should replace the TC under warranty There is a TSB regarding this. I'll see if I can find it for you.
