icp sensor
Old Aug 17, 2009 | 04:04 PM
arkredneck's Avatar
arkredneck
icp sensor
well pulled the connector on the icp sensor today and it was covered in oil i'm pretty sure that ain't good.
can i get this part from international or does it have to be a ford part?? what can i expect to pay for it?
Old Aug 17, 2009 | 04:18 PM
DRRXR's Avatar
DRRXR
Ebay
https://www.ford-trucks.com/forums/6...-so-cheap.html
Rocky
Old Aug 29, 2009 | 09:29 AM
arkredneck's Avatar
arkredneck
so what will a bad icp sensor make the truck run like?
Old Aug 29, 2009 | 12:08 PM
DRRXR's Avatar
DRRXR
Run poor
Generally your truck will run poorly. 2501105c1 Have a tendancy to leak oil and insulate the signal from the PCM. Then you may not have the right pressure to the injectors. At times the vehicle can surge for no reason, this is due to fouled out ICP or a leak at the ICP. Then the IPR is controlled by the PCM & then there is the calculated injection timing. So if either of the two, ICP or IPR are not working right then you can have performance issues. Simular conditions can be symptoms of low oil level in the HPOP or one that is on the way out. If the truck is idling you can try unplugging the ICP and see how it runs. It may idle rough or die.
Rocky
Mo info
https://www.ford-trucks.com/forums/7...hlight=bad+icp
https://www.ford-trucks.com/forums/8...hlight=bad+icp
Old Sep 4, 2009 | 10:31 PM
PAVEMENTMAN's Avatar
PAVEMENTMAN
Mine had an idle surge and when i unpluged the icp it smoothed out so i replaced it with a new icp and it still has an idle surge.
