Are they the same block?
Old Aug 15, 2009 | 11:58 PM
bcarless's Avatar
bcarless
Does the powerstroke and the 7.3 non-turbo use the same block? Could a Powerstroke be dropped into an "89 F series and bolt up the same? I'm just kicking some things around.
Old Aug 16, 2009 | 08:19 AM
farmert's Avatar
farmert
About the only thing the stroke and the idi share is the displacement of 7.3. That being said,the stroke can be dropped into the 89. The transmission would bolt up, but the stroke is a drive by wire, and the idi is mechanical. meaning the dash, footfeed for the throttle, computer for the engine, wireing and sensors wouuld have to be used from the donor truck. It is not just a simple motorswap.
Old Aug 16, 2009 | 10:43 PM
Dave Sponaugle's Avatar
Dave Sponaugle
It can and has been done.
But as said, bolting the motor in the truck is only the start.
Installing the electronics will take longer than installing the motor will.
