coolant dripping from transmission
Hi Everyone,
I have a 1995 F-150 4.9L manual trans with 137K miles. For the last couple of months I've had a coolant leak dripping from between the engine and the transmission. I just assumed that it was blowing back from the front of the truck when I drove it and then it would drip from there. Well, I've replaced the thermostat housing, thermostat, bypassed the heater core, replaced the radiator, all the hoses, and the water pump-all with no leaks. I just got back from the test drive after the new water pump and radiator and guess what...it's still dripping quite a bit from my transmission. I've had two mechanic's look at it and they can't find anything and so I thought I'd put it out there for you guys to discuss. Any help would be appreciated. I use this truck for hauling my Dune buggy out to the sand dunes and that season will be here shortly so I need the truck to be reliable.
thanks,
Nick
thanks,
Nick
I know, it is most likely a freeze plug or a head gasket, but on issue i had on mine that took me a while to figure out.
I had a pin hole leak in a heater hose. you could hardly see it even if you were looking. And it only leaked when i was driving for some reason. And when ever i would park and pop the hood every thing would be covered in coolant. It was extremely aggravating.
Again, i know you have looked over it carefully, but you never know.
Good Luck!!!
Good Luck!!!
Well, It turned out to be all the freeze plugs. I had to replace six steel ones with new copper ones and it was a real pain. I had to remove the transmission to get two and the intake and exhaust manifolds to get the rest. But, I did a bunch of work that needed to be done at the same time and the truck runs great. Thanks for the help.
oh yeah, we have a little rust out here but it's not too bad unless you live right on the ocean. The salt air really works over a vehicle. These freeze plugs are the only rust I have on any of my vehicles...
I got this truck from my brother and it's possible he didn't take proper care of the coolant as the freeze plugs were rusted from the inside out.
Freeze plugs.
I see the requirements for freeze plugs in cold weather areas but why not use a different metal type for the plugs Mr. Ford Engineer?
To late now....also happens with other manufacturers. I had an olds with a 350 and all the freeze plugs had to be replaced and it was a Texas car.
Coolant Maintenance issue by PO or poor design of the plugs? Who knows.
I needed the car and until I got bucks for a fix I drove it a mile, let it cool for 30 minutes then put in water then drove another mile.
Ahhhh the good old days.....
