Coolant flush
I'm shure there is a sticky on this, but wondered about the 3.0L specifically - I see those t kits for back flushing, but don't really feel keen about cutting a $50 heater hose (these were like 40-50 bucks, and dealer only when I replaced them 4 years ago)
But, if the back flush is the best way to go, I'm all ears - I'd love to get better heat in the winter, and maybe this will run the van a little cooler - it runs past middle normal with the air on lately.
So, my question is - is it a good idea to back flush? or should I just use one of those cleaners, etc
opinions? - anyone back flush and found it worked wonders on the older areos? - it has never been done on this one, and it's an 89 - the coolant looks like it could use a flush - not horrible, but not clear/green either...
Thanks
As for the whole system, I would pick up a container of prestone cleaner, dump it in and run the system for a while drain, rinse, and fill.
I don't know which thread it was but Pablo had a great idea of using something (orange juice, or something like that) for cleaning out the system. He will probably pipe in about it shortly.
The heater works in the van, but of course, here in New England, we have very cold winters... I actually don't know if it ever really put out that much heat - did the older vans have a problem with heat in really cold weather?
I also have heard that to pull it is kind of a nightmare job, and you need mirrors, etc, short of pulling the whole dash out.
The only way I'd change it, is if it ever leaked - then I'd have no choice (well, except to block it off :-))
Peak makes a T kit with their cleaner for $15, but I have heard that in some cars, you can actually ruin stuff doing a back flush - or I guess, by the fact that you are going backwards, can unlodge some bigger stuff in the HC, etc...
I guess I don't want to create more of a problem than not doing it at all, is what I was wondering...
93, how is your 97 AWD? - Did they ever made that in a Shorty? I kinda like the shortys...
If you're worried about the plastic T fitting disintegrating, you can replace it with a brass coupler after the flush. Most auto parts stores should have those.
My thought also was, instead of cutting the hose, maybe just take it off, and run a temp hose from the WP to the T, and then from the T to it, and then just re-connect the hose back as normal when done - it's not something I'm gonna do every day -
I'm temped to try it, since it's never been done, but thanks for all those that chimed in on it - always good to hear the pitfalls, or the good things about stuff, etc...
As for heat output, the single heater core system is not brilliant but adequate. It should be hot enough to feel like you want to move your hand from the airstream at the vents when working correctly. Mine takes about 10-20 mins in the -20c winter we get around here, to get full hot air from the system.
which Heater hose should I use to do this? our tap water is ok, but we never drink it, if that helps :-) - I have a couple of gallons of distilled water too I could use - just want to do it right :-)
do you have a step by step on it? - thanks
Also, new thing - I hear air gurgling in the HC, but when the van is cold, I take the Rad Cap off, and it's full - so how can I burp the system, if it's already full? - wonder why there is air there that I can hear?
Also, on the mechanical door type heater levers, is the system using the heater core, regardless of the position of that slider? - or is there a vaccum switch in line as well?
Thanks to all on this...
You can then install the flushing tee, open the drain tap & run the engine until the outflow is perfectly clear. Then drain the system & refill with 60% AF + Distilled water . I would change all suspect hoses and the thermostat while your at it.
As for my AWD, it has been running great. Just last week we went on a 800mi trip. I averaged 18.9 mpg, which I wish was more, but oh well, the trade off of fuel economy for room for the wife and three kids, all their stuff (and the kitchen sink) plus having a/c running in the front and back, and with the stability of AWD, it is hard to be beat.
i just add a bottle of Prestone radiator flush.
run for 1/2 hour at temp.
take out the thermostat, pull one of the hoses to the rear and front heaters and remove one end of the bottom radiator hose
i then blow out the system with a garden hose and nozzle only turned partially on. heater cores are only rated to handle 30 psi max.
nozzle into heater hoses flushes out the cores.
nozzle at full pressure into thermostat opening blows out coolant passages in engine which flush fitting will never get to.
best to remove radiator to do a complete flush on it as the core ends are where most crud collects in a mineralization deposit form. use a long commercial plumbers brush in thru hose holes to rod the ends, hose flush thru both sides. blow water thru from the backside of the radiator to blast all those sticky little road kill bugs out of the fins.
use compressed air to blow out much of the tap water.
seems like all I can find around here are the T back flush kits, and not just the stand alone flush product - I remember about not using a lot of pressure for the HC - I was actually gonna pull both hoses and run low pressure hose there....
I get a film on the top of my Rad fill - esp when it's really cold, you can see it, I usually drain and reload every 2-3 years, but I know it's never really been flushed with an agent... got to get that done before the winter comes...
Thanks to all - I'll see what I end up with... not sure I'm gonna pull the radiator, and get that into it, unless this is why the van is running a little hotter lately than normal - it was always at a 1/3rd on the gauge, and lately, I see it staying around the middle... would like it to be a little cooler, esp when air is on, etc...
BTW - a bit off topic - can I put a newer 3G Alt in the 3.0L without having to rewire anything? - thanks
most coolants will develop a slight film from the chemicals used for coolant system corrosion and water pump seal lube protection
i like to use a can of Prestone or Gunk coolant restorer and water pump lube every fall as and additive.
96 was my first and only Love Van.
only certain way to measure coolant temp is with a thermometer.
BUT - one other thing I noticed last couple of years, when it's raining outside, and like in the 50's-70's - you can smell a little bit of antifreeze sometimes around the passinger side, but outside the van - I see no leaks (heater hoses are right there, and they are fine, etc... it's strange... only when it's raining do you smell it... why? - am I crazy?
Still love my Van, and I'm the original owner of 20 years! - hope to have her another 20, and thanks to all of you, I might just get there! - not too many 89's like mine, unless they are CA or Fla cars...
Sounds like you have the start of a leak, check around the heater hose push-in connections ( does yours have the AC heater bypass valve ) plastic looking block with 4 hose connections & a bell shaped butterfly vacuum valve, I had one fail recently.
Any bubbles in the AFC with rad cap off at idle?
