Engine will not turn over
Old Aug 15, 2009 | 01:20 AM
Denis K's Avatar
Denis K
Everything had been running just fine, went to the store and when I tried to restart my truck, NOTHING!
All the dash lights come on, new batteries, when key moved to start position - no response, not even the clicking of the starter solenoid. Checked the fuses and relays, all OK for starter circuit. May be the neutral position switch or some other dumb thing. Any ideas?
2003 F550 7.3
Old Aug 15, 2009 | 06:54 AM
F350-6's Avatar
F350-6
Will it start in Neutral instead of Park?
Old Aug 15, 2009 | 08:59 AM
Denis K's Avatar
Denis K
I tried starting it in every position just in case Chris, no luck!
Old Aug 15, 2009 | 09:25 AM
Kwikkordead's Avatar
Kwikkordead
Time to get a test light and begin diagnosis.
Is there power to the solinoid when you turn the key to the start position? Stuff like that.
Old Aug 15, 2009 | 01:09 PM
SuperDoodie's Avatar
SuperDoodie
So when you go to start it, do all your dash lights and everything lose power?
Old Aug 15, 2009 | 01:36 PM
87 F-150 I6's Avatar
87 F-150 I6
maybe the started died or a wire just got loose on it so its not getting any power.
Old Aug 15, 2009 | 06:35 PM
rbaker6336's Avatar
rbaker6336
first I would jump from the battery post on the fenderwell mounted solinoid to the small post.If it spins then you have ruled out everything from the battry to the starter
if that works the problem is between the soliniod and the key
Old Aug 15, 2009 | 08:58 PM
F350-6's Avatar
F350-6
01 was the last year they did that Ray. My 02 doesn't have the fender mounted soleniod, even though the manual says it does. Battery cable goes straight to starter solenoid. You can still test for voltage or even short the terminals the same way, it's just easier to do it with test leads that have clips on them.
Old Aug 21, 2009 | 04:07 PM
Denis K's Avatar
Denis K
Like Chris and Ray suggested, I cut to the chase and tried jumping out the solenoid - nada - the starter was shot.
I had to have the truck towed because it was too close to an intersection to leave overnight - $600 later, the new starter performs just like the old one used to
How come it's never just a @!#$%^ fuse?
Thanks for your help guys!
Denis
anied52
18
Jul 22, 2016 04:56 PM
m.collins
36
Apr 16, 2015 11:42 AM
crkrstf
Mar 8, 2015 07:17 PM
ottawaair
1997 - 2003 F150
Aug 22, 2011 11:00 PM
robbyf250
Aug 16, 2010 10:18 PM
