Glowplug control??? Help
Old Aug 14, 2009 | 03:54 PM
High Intentions's Avatar
High Intentions
Mod Specialist ;)
I pulled a code off which is PO683....Glowplug control module to pcm communication circuit..
Any ideas on what I need to do to fix it???
Thanks for any help..
Eric
Old Aug 14, 2009 | 04:49 PM
duck fan's Avatar
duck fan
Because racetruck
Double check all the connections to the GPCM and clear the code.
Old Aug 14, 2009 | 05:17 PM
danskool's Avatar
danskool
Go Bills !
Just to add to Peter(with his search for Clay )
Post #2 https://www.ford-trucks.com/forums/7...-code-gpr.html by Robin has a pretty good pic of your set up.
Could be The GPCM ,Glow Plug/Plugs, GPCM harness connectors or the UVCH. The UVCH has claimed alot of lives by partial coming unplugged.
Old Aug 14, 2009 | 09:40 PM
High Intentions
Mod Specialist ;)
Thanks....The connections to the module look ok. On one of the other posts someone said they replaced the glowplug and it went away..
Old Aug 14, 2009 | 10:46 PM
duck fan's Avatar
duck fan
Because racetruck
In the case of the Excursions they have a GPCM. The code you are getting suggests the module has gone bad. Get in touch with partsguyed. I checked over the weekend and his price is like $122. I need a new one too.
Old Aug 14, 2009 | 11:14 PM
High Intentions
Mod Specialist ;)
Thanks Peter...you getting the same code???
Old Aug 14, 2009 | 11:39 PM
duck fan's Avatar
duck fan
Because racetruck
No, I am getting the code for the #s 2,4,6, and 8 glow plugs. No matter what I do with the harnesses. I get the same code all the time. When the GPCM goes bad you either get the code you got, the 4 I'm getting or the 4 for the passenger side glow plugs. The GPCM is nice to have when one glow plug goes bad cause you can diagnose which one. But when the GPCM goes bad its 3x as expensive as the Glow plug relay on the other trucks.
Old Aug 15, 2009 | 05:33 AM
High Intentions
Mod Specialist ;)
Thanks again Peter.....I went to his web site and tried to pull up the GPCM and nothing comes up.?? Are you still driving excursion? Do you know if it's ok to keep driving it until I get the GPCM?
I love this site.....There is always someone here with the info one needs to fix their problem.
Old Aug 15, 2009 | 12:29 PM
duck fan's Avatar
duck fan
Because racetruck
I am still driving the truck. There is nothing wrong with doing so except that it will be hard to start once it starts getting cold out. I checked out Ed's site and the link for the GPCM is here: http://www.trademotion.com/partlocat...layCatalogid=0
Old Aug 15, 2009 | 07:41 PM
High Intentions
Mod Specialist ;)
Thanks again.....
