96 F-150 missing
Old Aug 14, 2009 | 03:30 PM
matress21's Avatar
matress21
96 F-150 missing
hey i got a 96 F-150 with a 351W and when your getting up to speed at half throttle it feels like its missing or not getting enough gas. i ve done a full tune up on it and its still doing it. thanx mat
Old Aug 14, 2009 | 03:43 PM
DBGrif91's Avatar
DBGrif91
Have you checked fuel pressure? You may also want to check your throttle positioning sensor- sometimes they get worn out in a certain area and cause poor performance- it's usually at idle or when you're at speeds you drive on a daily basis, but I've seen them go bad in between those areas as well. Let me know if you don't know how to do it- I'll look up the procedure for you in my service manual.
Old Aug 14, 2009 | 03:51 PM
matress21's Avatar
matress21
yea if you could look that up that would be great. thanx alot
Old Aug 14, 2009 | 06:48 PM
DBGrif91's Avatar
DBGrif91
Will do, but I need to know what size engine you have in it before I can give you the correct specifications.
Old Aug 14, 2009 | 08:19 PM
matress21's Avatar
matress21
its a 5.8 (351)
Old Aug 14, 2009 | 11:39 PM
alxsnmr's Avatar
alxsnmr
Reference fordfuelinjection.com, and look up the throttle position sensor. While you are read up on how to pull the codes with a paper clip, or short piece of wire. It is also a good idea to pull the codes even if the truck doesnt have the CEL lit. You will also need a Digital Multimeter.
Old Aug 15, 2009 | 05:58 AM
DBGrif91's Avatar
DBGrif91
alxsnmr is right- go to fordfuelinjection.com and follow their procedure for checking TPS. Compared to the one in my service manual it is less confusing- the one in my book is the kind of procedure I'd need to be right there at the truck to perform. FFI.com is much simpler... or at least, better explained.
