Cold Start Surge
Old Aug 13, 2009 | 11:20 PM
Dwain65's Avatar
Dwain65
Cold Start Surge
I bought an '00 Ex 4X2 7.3 a few months ago and have experienced a weird surge when I cold start the engine. The outside temperature is 80+ degrees. I turn the key on let the glow plugs heat up and turn the key. The motor surges up to about 1000-1200, back down to 500-600, and it does this about 4 times then smooths out at 900 rpm. I also noticed puffs of smokecoming from the tailpipe while it is doing this.Any thoughts?D
Old Aug 14, 2009 | 01:05 AM
Stewart_H's Avatar
Stewart_H
Post this question in the 7.3L PSD forum.
The guys in that forum are the experts when it comes to everything 7.3L related.
Stewart
Old Aug 14, 2009 | 07:18 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Stewart
This definitely sounds odd, I'll get this moved...
Dwain65, where do you live?
Old Aug 14, 2009 | 07:49 AM
clux's Avatar
clux
Do a search for "the romps" in this forum, see if that describes your symptoms.
It's one of the things these engines do sometimes, seems to be engine oil and ICP related. Generally speaking switching to a 5w-40 weight oil will cure it.
Old Aug 14, 2009 | 08:32 AM
Toreador_Diesel
Man! I forgot the last time my truck romped like that....
Something you may try before you switch to 5w-40 is two bottle of Prolong oil additive. It smoothed out my idle and my truck performs better overall. Get to bottles from Autozone, pour it in with the truck running, find a good long stretch of freeway, set the cruise at 65-70 for about an hour, and let it do it's thing.
It also sounds like you need the updated ICP sensor too, it's located on the driverside front of the engine with a connector going to it. The intercooler hose will be blocking it, but if you go topside on the engine you'll see a gold sensor with a connector going to it.
Old Aug 14, 2009 | 11:28 AM
Stewart_H's Avatar
Stewart_H
I thought of the romps too, but he said it was 80+ degrees outside and it was my understanding the romps only occurred when the temps are a lot colder than 80.
Stewart
Old Aug 14, 2009 | 12:45 PM
Action4478's Avatar
Action4478
How old is the oil & is it full?...
Also , try starting it in neutral ,see if it still romps ..
Old Aug 14, 2009 | 11:46 PM
Dwain65's Avatar
Dwain65
Thanks Toreador. Yes we live near Argyle, just north of DFW airport.
Dwain
Old Aug 14, 2009 | 11:54 PM
Dwain65's Avatar
Dwain65
Yes, the oil is full. When I bought the truck the oil was light brown but since it had not been changed since February I went ahead and had it changed at the Ford store. I'll try the neutral idea.
Thanks,
Dwain
Dr. Dirt
1997 - 2003 F150
Jan 5, 2013 08:49 AM
cajunsuperduty
Oct 28, 2011 03:31 PM
Pikachu
15
Jul 15, 2004 08:17 PM
RMike
Sep 26, 2001 03:25 PM
