Multiple brake problems.....
Old Aug 14, 2009 | 09:03 PM
boggerted's Avatar
boggerted
okay, I have done rotors on these trucks before and they involved pounding t he studs out, so no big deal, I was just wondering if this truck also used this system. I will try to bleed the MC and also replace the rotors. I was also wondering if brake pads could "go bad" even with a decent amount of material left on them. They just dont seem to grab.
Old Aug 14, 2009 | 09:27 PM
danr1's Avatar
danr1
Yea previous owner could have used cheaper non metallic pads on it that have long since glazed over the rotors, drums as well as the pads/shoes.
Could also have less or nothing to do with pad type, just driving habits of the PO.
I use premium metallic pads, tends to tear up the rotors/drums faster but I tow a lot and want the extra bite they afford.
Old Aug 14, 2009 | 11:05 PM
EPNCSU2006's Avatar
EPNCSU2006
Dam, yea if the op asks for a rotor/hub assembly that is what he'll get. The assembly includes new bearings, races come already installed in the hub.
If the OP asks for rotors that is all that will come in the box, why spend the extra on hubs if they're not needed. Two rotors for 35 bucks each or two hub/rotor/bearing assembles for 100 to 160 bucks each depending on exact application. The rotors he has may just need turned for 12-15 bucks each.
That's my fault, I was thinking about 2wd front rotors/hubs on the F150 which are all one unit.
4CFarms
19
Oct 31, 2014 02:34 PM
ma115
Aug 23, 2012 09:51 PM
Jspafford
Bronco II
Dec 7, 2007 05:52 PM
hunter1897
1966 - 1977 Early Broncos
Jul 1, 2007 08:49 PM
mikenusaf
Apr 9, 2005 10:10 AM
