Sponsored by: Auxito
adding cruise control
Old Aug 13, 2009 | 09:10 PM
benblaque's Avatar
benblaque
I have a 2004 heritage 4.2 4x2 5 spd. does not have cruise cont. I would like to add it...
has anyone added one on their truck???
which one do you recommend???
thank you.
Old Aug 15, 2009 | 01:41 AM
bones2000's Avatar
bones2000
I added cruise control on a 2000 f150 5.4.
from memory...
I got a steering wheel and cruise control unit from a junk yard.
I was able to solder extra wires in my clock spring but you might want to get that from a junk yard too. (the clock spring cable had all the needed wires they just where not used)
I bought a Ford 2000 F150 electrical manual from eBay (this helped a lot)
Did a lot of research in this forum for help. (this helped a lot too)
My f150 had all the cabling on board. I did short out the safety cable that goes to the brake master cylinder.
cruise works good... light on dash even works
hope this helps
Old Aug 15, 2009 | 12:13 PM
benblaque's Avatar
benblaque
wow that sounds great.... how much did you have invested in doing it that way?
also, did you have to unhook the airbag to switch the wheel?
Old Aug 15, 2009 | 01:13 PM
bones2000's Avatar
bones2000
I used the same airbag that came with my truck and got the junk yard steering wheel for the cruise switches. Be VERY careful unhooking your air bag when swapping the steering wheels - read up in the forum about the airbag. I had been into my airbag before to fix the horn switch. It's not hard just be careful so you don't set it off.
Ford put a cruise kill switch in the brake master cylinder - in case the switch the turns on your brake lights fail - you could still stop your cruise control.
<<<BUT>>> they run a hot wire to the master cyl. kill switch, hot even with the key off. If the switch guts ever broke down you had flammable brake fluid on a hot wire. So these trucks with factory cruise were known to catch fire even when not running in the middle of the night in your garage.
So i did not put on a master cyl. kill switch. and just shorted the wire going to it and trust the brake switch at the petal.
It's been three years since i did mine and i have not had any problems.
How much in vested??
again from memory....
the most expensive part was the cruise unit and it was 65.00 i think?
I think the steering wheel was $50.00
The electrical manual - eBay - i cant remember $$ - but i use it all the time, my truck was a XL work truck and i have been putting in XLT parts in it so the manual has been very useful
The cruise control looks and works just like stock
bones2000's Avatar
bones2000
***BUT*** they run a hot wire to the master cyl. kill switch, hot even with the key off. If the switch guts ever broke down you had flammable brake fluid on a hot wire. So these trucks with factory cruise were known to catch fire even when not running in the middle of the night in your garage.
54LFL
Sep 9, 2018 10:53 AM
fordiesel69
2004 - 2008 F150
Nov 16, 2017 08:40 AM
rchrist72
1997 - 2003 F150
Jul 19, 2017 01:07 AM
ErrorS
1978 - 1996 Big Bronco
Dec 5, 2011 08:22 PM
paulkcbulm
Jan 5, 2010 01:28 PM
