Rough idle at stops
Old Aug 19, 2016 | 12:39 PM
76vetteluv's Avatar
76vetteluv
Rough idle at stops
I just bought a 05 Expedition 5.4l 155k miles. Check engine light was on when purchased. I took a chance. It has a rough idle at startup for a brief second or two. After that it drives fine. Plenty of power, smooth. When I come to a stop light, it starts idling rough again and feels like it's going to stall. Feather the gas a little and smooths back out. I had the codes checked. Was a cam shaft position sensor code. I replaced both sensors and the problem still exist but no check engine light. Can anyone give me some advice.
Old Aug 21, 2016 | 03:05 PM
R&T Babich's Avatar
R&T Babich
I would first check all the vacuum lines for leaks, particularly the PCV hose where it connects to the throttle body.
Sounds like the Idle Air Control valve might need to be replaced.
Try cleaning your old one which may help for awhile to see it's the problem.
Old Aug 21, 2016 | 05:04 PM
76vetteluv's Avatar
76vetteluv
Thanks, I'll check those. My check engine light came on again. Code shows cam shaft sensor again. I know those are new, I'm going to start checking wires to them. Would anything else give me that code. Thanks
Old Aug 28, 2016 | 08:33 PM
z31freakify's Avatar
z31freakify
Every time both banks show up is due to the VCT solenoid being clogged or your cam phasers are worn to the point where they advance or retard the timing where they please.
Old Aug 28, 2016 | 10:27 PM
R&T Babich's Avatar
R&T Babich
You changed both cam sensors and you indicated there was only one code.
What code did you get?
Old Aug 28, 2016 | 10:58 PM
76vetteluv's Avatar
76vetteluv
So I'm now getting 6 codes.
P0345 Camshaft position sensor A circuit bank 2 comes up twice.
P0455 Evaporative emissions system leak detected gross leak/no flow comes up 4 times.
Old Nov 23, 2016 | 05:53 AM
Excell's Avatar
Excell
P0345 could be the solenoid that operates the phaser.Or the phaser its self .There is a video on U tube how to check it and replace it .Google search .
P0455 make sure the gas cap is on tight .You kinda need some special equipment to
diagnose that one .
Old Dec 21, 2016 | 10:50 AM
zephyrprime's Avatar
zephyrprime
With P0455 it sounds like you have an air intake leak. Easy to fix.
With P0345 it sounds like either the wiring is bad or the computer on the truck is bad since you already replaced the camshaft sensor.
Old Jan 8, 2017 | 11:34 AM
Brad Brown's Avatar
Brad Brown
any update on the fix? Maybe??
amosjk
1983 - 2012 Ranger & B-Series
Jul 13, 2008 07:05 AM
short76
Oct 24, 2006 06:19 PM
litt810
Feb 25, 2005 10:54 PM
Volk
13
Jul 31, 2004 10:21 AM
thebigshow644
1997 - 2003 F150
Dec 30, 2003 11:07 AM
