door panels
Old Aug 13, 2009 | 07:49 PM
down2earth1928's Avatar
down2earth1928
door panels
My door panels have about had it.Im thinking about getting some new ones or trying to come up with some custom ones.Has anyone made some or have any ideals.all input and pics are appreciated.
Old Aug 13, 2009 | 08:58 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Door panel idea's
Here is an idea, have also heard of putting chrome diamond plate panels overlays where the silver part around the window crank and the lower black area.
Try a thread search on "door panels idea's" I have seen some pretty cool ideas on there.
Its easy to change the arm rest pad to change the color up a bit. I think you can get diamond plate in different colors, red, blue ect...
Can also get some lower map pocket/drink holder panels from a 80 ish and up truck?
Old Aug 13, 2009 | 09:01 PM
down2earth1928
ok,thanks.I will do another search.I did one didnt have much luck.I will try again.
Old Aug 13, 2009 | 09:09 PM
hp246's Avatar
hp246
Believe it or not, these folk make custom panels for the dent sides: http://www.roddoors.com/
I've been contemplating this too. Some things I'm considering are aluminum panels, or maiking my own out of 1/8 inch plywood.
Old Aug 13, 2009 | 09:15 PM
Diesel_Brad's Avatar
Diesel_Brad
Dont mean to highjack the thread.........but. How can i get the "woodgrain" insert off the door panels so i can paint the door panel. I want to save the woodgrain cuz i have yet to see them in any catalog
Old Aug 13, 2009 | 09:20 PM
hp246's Avatar
hp246
Good question. You might want to check out a restoration board.
Old Aug 13, 2009 | 09:26 PM
mudder460's Avatar
mudder460
Here is mine with diamond plate overlays. Once you pop off the panel, you can take a needle nose pliers and gently squeese the tabs and the overlay comes right off.
good luck and have fun with it!
Old Aug 13, 2009 | 09:27 PM
down2earth1928
I have thought about wood panels.where im hung up is on the armrest.
Old Aug 13, 2009 | 09:28 PM
down2earth1928
thanks the diamond plate looks good
Old Aug 13, 2009 | 09:29 PM
hp246's Avatar
hp246
I saw a presentation by the guys from rod doors. You can mold in your own arm rest with their stuff. I/ve seen rodders use light wood with foam padding glued to it. The wood is glued to the doors. The whole thing is upholstered.
Old Aug 13, 2009 | 09:50 PM
down2earth1928
I will check them out.
Old Aug 14, 2009 | 02:22 AM
Skip1970's Avatar
Skip1970
bet that metal panel is COLD in the winter on the arm!
Old Aug 14, 2009 | 08:50 AM
mudder460's Avatar
mudder460
I dunno yet. I am sure it will be, I just put it in this summer. I know it gets pretty warm!
Old Aug 14, 2009 | 08:55 AM
fmc400's Avatar
fmc400
MSEE
I bought new door panels from Dennis Carpenter; they worked out really well. It ran about $200.
Old Aug 14, 2009 | 09:02 AM
70 Bronco TX's Avatar
70 Bronco TX
I just received the same pair (although yet to install) and they do look nice. I'm pleased so far.
