V Code, Or X code / B code Spring Part Numbers.
Old Aug 13, 2009 | 05:13 PM
Ex1900Driver's Avatar
Ex1900Driver
Hi...
I have done an extensive search and pretty have all the information I need.
That being said I want to confirm with you all the part numbers. Do I have these right??
Rear "B" Codes - 3C3Z-5560-CB
Front "X" Codes - 2C3Z-5310-AF
Front "V" Codes -
2C3Z-5310-HA
As you see I put both the front X and V code to be verified because I haven't decided which ones to use.
The only part numbers I am missing are the front and rear Axle U bolts and nuts to use.
I know there is a difference between the slightly flatter ones and the rounded ones. So what are the ROUNDED Axle U bolt part numbers I need?
Also should I just go with the front V codes or go all the way up to the X codes? What do you think??
Thanks for the help
GDC
2000 Excursion 7.3 PSD All stock except tires 285/75/16
Old Aug 13, 2009 | 07:50 PM
CanadianSmokie's Avatar
CanadianSmokie
Can't help ya on the part numbers but if you are between the V and the X you might want to consider the W codes. They are the springs off the F450. Not as stiff as the X's but will give a bit more lift than the V's.
Old Aug 14, 2009 | 12:32 AM
Ex1900Driver
I appreciate that info. I never really considered the "W"s... another decision to make!!
Old Aug 14, 2009 | 12:50 AM
Stewart_H's Avatar
Stewart_H
You have the correct part numbers for the V codes and the B codes.
Stewart
Old Aug 14, 2009 | 10:34 PM
Ex1900Driver
Stewart
I appreciate that information.
Thanks
Old Aug 14, 2009 | 11:10 PM
Stewart_H's Avatar
Stewart_H
You're welcome.
Stewart
Old Aug 15, 2009 | 12:20 AM
99FORD EXPY.'s Avatar
99FORD EXPY.
good luck, i just did mine a couple of weeks ago wow what a differance
Old Jan 19, 2011 | 08:49 PM
01EX's Avatar
01EX
subscribing
Bluzilla
Jan 30, 2020 09:53 PM
lovestrucks
Mar 2, 2012 03:01 PM
German Joe
Large Truck
Feb 28, 2012 12:36 AM
Big-old-460
61
Sep 7, 2010 09:49 PM
PhilfromFlorida
Apr 2, 2008 03:50 PM
