Clicking Noise From Distributer?
Old Aug 13, 2009 | 02:42 PM
MT-F250's Avatar
MT-F250
I was just wondering if anyone knows if this is normal? My 1979 F250 with a 400 engine - there is a continuous clicking noise at the distributor with the ignition key on, without the engine running. It sounds like it is coming from under the distributor cap.
Sorry if this is a stupid question, I haven't worked on anything this old for quite a number of years. I can't remember all the nuances of these old vehicles.
Old Aug 13, 2009 | 03:26 PM
montana_highboy's Avatar
montana_highboy
With the key in the "run" position the coil is still energized whether the distributor is turning or not, might have something to do with the clicking noise you hear.
Old Aug 13, 2009 | 04:28 PM
MT-F250's Avatar
MT-F250
I was checking my 1990 F250 with a 460 and the distributor doesn't make the clicking sound. It seems like the ignition sysem is similar.
Old Aug 13, 2009 | 04:52 PM
Furyus1's Avatar
Furyus1
Just a thought but have you pulled the distributor cap and looked at everything inside while the key is on to see if anything is sparking? A spark discharge can make a clicking noise...
Old Aug 13, 2009 | 05:10 PM
MT-F250's Avatar
MT-F250
That was shocking when I pulled off my distributor cap...literally! I went out and pulled it off with the key off and got zapped.
Somethings got to be wrong with this doesn't it?
Old Aug 13, 2009 | 05:17 PM
Furyus1's Avatar
Furyus1
With the key off? Yup, something's wrong. What condition is your cap and plug wires in?
Old Aug 13, 2009 | 05:38 PM
MT-F250's Avatar
MT-F250
Sorry mispoken- key was on!
I recently replaced the cap and rotor (Accel), new coil (MSD), new plug wires (MSD), and new spark plugs.
Maybe about 800 miles on them.
Sorry for the confusion.
Old Aug 15, 2009 | 10:09 AM
MT-F250's Avatar
MT-F250
Anyone have any other advice on what may be wrong with my Ignition System.
Thanks.
Old Aug 15, 2009 | 10:57 AM
fmc400's Avatar
fmc400
MSEE
How fast is the clicking noise? Does it seem consistent with engine RPM? That is to say, if you open the throttle to raise the RPMs, does the frequency of the sound increase as well?
Old Aug 15, 2009 | 12:11 PM
75F350's Avatar
75F350
I believe that the OP said that the noise occurs when the engineis off and the key is on.
Something is allowing the coil to trigger and discharge. Only replied to subscribe. This is interesting. Just happen to have a DII on the bench. Im gonna go wire it up to see if I can duplicate. I am supposed to be working an a bad COP for a Super Duty right now, but I have to wait for parts to be delivered anyway.
Old Aug 15, 2009 | 12:32 PM
75F350's Avatar
75F350
Ok, I managed to shock the heak out of myself by trying to duplicate this problem. All wired up and functional, I cant duplicate the noise, though I do get a humm just before the snap when the coil discharges, and I am wondering if the OP has changed anything other than the cap and rotor. Is there any possibility that there is a short? in the dizzy or anything loose inside? Perhaps a crack in the rotor itself? This does not explain the trigger situation, but something is making this dizzy trigger. The spark has found a ground creating the false trigger. Seems like when the engine is running the resistance through the plug is less than the actual short, and it fires the plugs, so there is some resistance involved with this short.
Any debris, or metal shavings inside of the dizzy itself?
Old Aug 15, 2009 | 01:11 PM
fmc400's Avatar
fmc400
MSEE
Sorry about that, thanks for the clarification.
In that case, with the key ON, it's likely the module is firing the coil inadvertently. It's either doing this because the Hall Effect sensor in the distributor is erroneously triggering the module, or the module has a short and is firing the coil regardless of the distributor signal.
The challenge here is to find which of the two scenarios is the case without trial-and-error. Does the engine run fine otherwise? Is the clicking sound periodic and steady, or random?
Old Aug 15, 2009 | 01:57 PM
MT-F250's Avatar
MT-F250
The clicking sound is steady with the engine off and key on. The engine runs good when running.
I wouldn't think the cap is bad as it is brand new. youv'e kind of lost me on the dizzy trigger-not sure what that is
Old Aug 15, 2009 | 03:16 PM
Furyus1's Avatar
Furyus1
Steady discharge rate - coil saturating then discharging? He did say he changed out the coil...
Old Aug 15, 2009 | 03:18 PM
USArmyTaterness's Avatar
USArmyTaterness
sounds like the distributors triggering a fire when there is not one being called for
