Exploring exhaust options
Old Aug 13, 2009 | 02:29 PM
79FordBlake's Avatar
79FordBlake
Soon I will be ready to put a new exhaust on the 73 f100(302). Its a short wheel base truck and I am for sure going with true duals. I thought about having the pipe only ran to about the back off the cab then going into a pair of cherrybombs and then thats it. Anybody have any problems with the exhuast getting something hot that it shouldnt be like this? I know it will be pretty loud. I kinda like the way a truck looks when you cant see the exhaust coming out the back or out the sides. I've seen some people bolt glasspacks straight to their headers but I don't think I like that idea. Thanks.
Old Aug 13, 2009 | 02:33 PM
zak8tac's Avatar
zak8tac
The only problem with this is if your stuck in traffic and the fumes are getting into your cab
Old Aug 13, 2009 | 09:23 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Consider using a cross over pipe and maybe turn outs in front of the rear tires?
Could also but some turn downs on the ends of those mufflers.
Old Aug 14, 2009 | 11:42 AM
65f100_352's Avatar
65f100_352
On my 65 it dumps before the rear end and I've never had a problem.
Old Aug 14, 2009 | 12:17 PM
AK FORD GUY's Avatar
AK FORD GUY
That's not a bad idea. Turn-downs aiming towards the back of the truck just before the rear axle. That should push most of the exhaust fumes to the rear and I think you would only see it if you were looking for it. Having the exhaust bounce off the ground gives it a different sound also.
Old Aug 14, 2009 | 12:21 PM
USArmyTaterness's Avatar
USArmyTaterness
it also matters what you plan to do with this truck is it a street only truck do you ever race it 4x4 what I use a dual exauhst out the rear under a roll pan with cut outs before the muffler for the strip
Old Aug 14, 2009 | 12:37 PM
79FordBlake
I may have turn downs after the cherry bombs. Its just going to be driven on the street its 2wd. Both of my other trucks are fairly quiet so I wanted one to be loud, lol.
Old Aug 14, 2009 | 01:11 PM
USArmyTaterness
pour oil in the cherrry bombs before installing them make sure to get it all over the glass
Old Aug 14, 2009 | 01:40 PM
79FordBlake
Ok this may be a stupid question, but why would I pour oil in brand new cherry bomb glasspacks?
Old Aug 14, 2009 | 01:42 PM
Holiver31's Avatar
Holiver31
I think it helps protect the fiberglass from heat and such, and prevent blowouts. Right?
Old Aug 14, 2009 | 02:52 PM
USArmyTaterness
actually does the exact opposite it burns out the glass basically turning it into a sound grenade with out exploding
I forgot to mention get used to the sound ordnance tickets
Old Aug 14, 2009 | 04:46 PM
dkf's Avatar
dkf
I never confirmed it myself but I've heard from some reliable guys that the Cherry Bombs have a necked down core compared to the inlets on some of the glasspacks. Flowtech Red Hots were recommended.
If you don't want to go over the axle exit the pipes out directly in front of the rear tires. The problem with dumps in front of the axle is they can bounch a lot of noise off the road and be annoying. I got duals out the back on my 74' 302 and like it a lot.
Old Aug 14, 2009 | 05:26 PM
shadowviper12345's Avatar
shadowviper12345
yeah this happens to me, and my exhaust is blowing on the e-brake lines.
Old Aug 14, 2009 | 05:29 PM
USArmyTaterness
why not put a small 10 degree turn on them
Old Aug 14, 2009 | 09:33 PM
77&79F250's Avatar
77&79F250
I heard you can also heat up the outside of a ol cherry bomb with a rose bud tip on a oxy torch, and then blast water in there to break up the fiberglass to make it louder.
But that might be a urban legend, ? I run headers to straight stacks on my mudder and do not worry about it. And YES its loud!
