Please Help! 2000 Excursion thuds when I stop
Old Aug 13, 2009 | 09:28 AM
vicalcmore2's Avatar
vicalcmore2
Red face Please Help! 2000 Excursion thuds when I stop
My excursion thuds when it comes to a stop. I have replaced most of the front end...Drag link bar, ABS hubs, brakes and rotors, stabelizer shock, all 4 main shocks, had the tires rotated and an alignment. I have different mechanics all telling me different reasons. I just put $2000 into the front end because I was told that was where the noise was comming from and now that it has not fixed the problem, Im told its comming from the back end. I was told that the back end rolls a good 4" and that is not normal, to replace the leaf springs. Another ford mechanic said that 4" roll is normal and it's the slip yolk??? Whatever that is! A third ford mechanic said that it's the leaf spring bushings that are causing the problem. I really feel like I am being taken advantage of because I am a woman and have no clue about Ford Excursions. If you have any advice or ideas please let me know.
Thanks!
Renee
Old Aug 13, 2009 | 09:38 AM
sddesigns's Avatar
sddesigns
FTE Leadership Emeritus
FTE Emeritus
Have they greased the slip yoke? Mine did it until I had my mechanic do this procedure on mine.
The write up says when you put it in gear, mine did it when I stopped, and started even when rolling or from a full stop. Haven't heard it again since having it done 10 months ago.
http://www.eurekaboy.com/f250/slipjoint.htm
Old Aug 13, 2009 | 06:44 PM
vicalcmore2
Thank you so much I will ask my mechanic to do that before I sink a larger ammount of $$ into it.
Renee
Old Aug 13, 2009 | 07:50 PM
UrbanXX's Avatar
UrbanXX
I would think the post by Saddesigns is the correct fix for your problem.
This is a common problem for some unknown reason. I seen this discussed by a drive shaft shop and on this forum also. Just one of those weird little quirks that happens.
Old Aug 14, 2009 | 12:00 AM
EXv10's Avatar
EXv10
Any mechanic that takes advantage of a woman should be shot at sunrise. +1 on the slip joint (a 20 minute part free job).
Old Aug 14, 2009 | 07:25 AM
Toreador_Diesel's Avatar
Toreador_Diesel
I agree on both....
Old Aug 14, 2009 | 07:28 AM
Toreador_Diesel
Thanks!
Renee
If you like, depending on where you live one of the guys and gals on the RHN or Roadside Help Network could come give you a hand and save you a trip to the mechanic. We're here to help each other and not afraid to get our hands dirty. Let me know if we can help...
Old Aug 14, 2009 | 08:00 AM
first truck's Avatar
first truck
Has anyone put a grease fitting in the yoke? seems like a good place for one.
Old Aug 14, 2009 | 08:45 PM
EXv10's Avatar
EXv10
They should last a long time and not that hard to service.
Old Aug 15, 2009 | 01:35 PM
Rushmore X's Avatar
Rushmore X
Mine was making a similar noise. Found out the bushings around the front sway bar were worn, allowing it slip...
larz12345
Dec 5, 2016 01:30 PM
david9dr
Oct 5, 2016 01:48 PM
Metz22
13
Mar 1, 2016 08:09 AM
backdr10
Feb 22, 2011 03:41 PM
unrepentant_sinner
1997 - 2003 F150
Apr 6, 2004 07:18 PM
