390 Ribbed block
Old Aug 12, 2009 | 11:40 PM
erynod1's Avatar
erynod1
390 Ribbed block
I think my truck has one of these i can see the ribbing on the side rite above the oil pan is there any other ways of knowing?
Old Aug 13, 2009 | 12:09 AM
keisha9's Avatar
keisha9
i believe there would be a "105" stamped on the driver side of the block . right below the head instead of "352" or "390".
Old Aug 13, 2009 | 05:49 AM
jowilker's Avatar
jowilker
Have you seen one with 390 on it, I don't think I ever have.
John
Old Aug 13, 2009 | 11:19 AM
bertha66's Avatar
bertha66
I have not seen a 390 with the ribs, But all the 360's that I have had in the past, did have them. I'm NOT saying that all 360's did, just the one's that I had. On some of those 360's we turned into 390's, so they had the stoke of a 390, but started out life as a 360.
Old Aug 13, 2009 | 12:22 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
It'll either be a reversed 105, or 352 cast into the block. Never heard of "390" on the block. Ever.
Old Aug 14, 2009 | 08:29 PM
SIXD9R's Avatar
SIXD9R
Sorry to jump in with a dumb question but what's a "ribbed" block?
Old Aug 15, 2009 | 08:57 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
Ribbed block is a 71 or later FE block that has vertical ribs going down both sides. Both DIF "352" and MCC reverse "105" blocks can have them. Reason is two fold, first to help support aging molds as blocks were cast or to give more structure strength to the block itself. No one really seems to know the exact reason. There were some non ribbed blocks late in production (75-76) so who knows?? LOL
Old Aug 15, 2009 | 09:17 AM
Barry_R's Avatar
Barry_R
Don't know if it applies to cast iron blocks, but ribs and such are normally used in castings to allow for better fill of critical areas during the pouring process. You'll see them as well as cross hatch patterns on intakes and pistons too.
Old Aug 15, 2009 | 11:45 PM
keisha9's Avatar
keisha9
ribbed for her pleasure?
Old Aug 16, 2009 | 11:29 PM
393STROKER's Avatar
393STROKER
I have a `71 F-250 w/390 that is ribbed.Read somewhere that it beefs up the block walls.Ribs are good.
Old Aug 17, 2009 | 08:54 PM
SIXD9R's Avatar
SIXD9R
Thanks for explaining FFR428. I gotta look at my block now. It's a 390 with 352 cast into it that i know for sure. Don't think it has the rib's but I will take another look.
Old Aug 18, 2009 | 02:25 PM
scottfreeman's Avatar
scottfreeman
'71 or later?
Old Aug 18, 2009 | 04:54 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
Originally Posted by scottfreeman
'71 or later?
Well there are exceptions to everything and the FE engine is a perfect example. There have been 427 and 428 blocks as early as 68 with ribs on them. But they consistantly weren't there till 71 and later.
Old Aug 18, 2009 | 07:09 PM
SIXD9R's Avatar
SIXD9R
'71 or later?
Actually I don't know. It's in a 69 stang but a previous owner transplanted the 390 in there. Origional motor was a 302.
I'm going to have to go back and look at some pics when the motor was out of the car to see if it has ribs. I can't see much of the side of the motor at all in that tiny engine compartment.
Old Aug 18, 2009 | 07:28 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
Glad to help.
