Sponsored by: Real Truck
steering issue
Old Aug 12, 2009 | 10:32 PM
fordguy622's Avatar
fordguy622
steering issue
Hi All,
Over the last couple days (I will do my best to describe issue) I noticed that when driving and making ***some*** turns, the steering wheel will not return all the way. You can feel tension, and I have to return it to center. I dont hear any grinding, clunking....no noises. Where would you start to look for problems? I was thinking of just replacing the steering stablizer first, as it is original and see if that helps. Any other suggestions welcome...
Ron
Old Aug 13, 2009 | 06:33 AM
Monster-4's Avatar
Monster-4
It can be the stablizer or possiable the steering box. Also not sure if you have 4X4 but if you do it can be axle u-joints or the bolts that hold the wheel hub on could be loose.
Old Aug 13, 2009 | 06:40 AM
FortyFords's Avatar
FortyFords
I see by his sig,that is a 4x4 ,and you have a plow.
The extra weight of the plow can cause steering parts to wear at a faster rate.
Start by checking the front balljoints and u-joints for binding.
What do your front tires look like? any scaloping or uneven wear pattern?
Actually any worn steering component can cause this.
Rich
Old Aug 13, 2009 | 12:09 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Don't go buying a new stabilizer, just remove it and test drive it
Otherwise, could be lots of things, keep to get into it like Rich says.
