Changing Flywheel
Old Aug 12, 2009 | 08:47 PM
thecardoc's Avatar
thecardoc
Changing Flywheel
Need to change the flywheel on 97 5.4L Expy 4x4 with bad teeth . On older stuff I used to put long studs in the bellhousing bolts and sneak the transmission back just enough to get to the flywheel bolts , and not having to pull the trans out. Is the enough room to do this or has any one done it this way on this newer stuff.
Old Aug 12, 2009 | 11:04 PM
alloro's Avatar
alloro
I don't know if your idea will work because besides the tranny, you have the transfer case and front drive shaft to deal with.
mherlihy
Feb 7, 2016 07:53 PM
Tomahawk2506
Jun 3, 2013 10:05 PM
oldschool_77
Jul 15, 2010 11:12 PM
rickgthf
Oct 21, 2006 04:43 AM
