condenser fan
Old Aug 12, 2009 | 07:41 PM
xplorerboy's Avatar
xplorerboy
condenser fan
i want to put a condenser fan on my 01sport trac..i dont know where should i connect the wiring..any help..thank's
Old Aug 12, 2009 | 09:37 PM
steve(ill)'s Avatar
steve(ill)
what is the condenser fan going to do? air cond? do you want to run continuous or on and off with what signal?
Old Aug 12, 2009 | 11:11 PM
xplorerboy's Avatar
xplorerboy
condenser fan
yes i want to use the condenser fan for my air conditon and i want it on when i use the ac and off when it's not in use..so where should i connect the wiring?any advice..thank's..
Old Aug 13, 2009 | 06:53 AM
shorod's Avatar
shorod
I'm not sure how much the output from the PCM for the A/C clutch relay can safely source, so I'd suggest tapping in to the output (gray/white wire) from the A/C clutch relay to the clutch, run that tap to the coil of an additional relay that can handle the current draw of the new fan, and using that relay to switch the new fan on and off.
I'm curious though why you want to add an electric condensor fan rather than using the OEM configuration. If it's due to effectiveness, you might have a fan clutch issue or debris in the condensor. These vehicles are tested over large temperature extremes to make sure they can handle the environments they are exposed to in the stock configuration.
-Rod
morph1175
Aug 28, 2011 04:30 PM
ducktang
Oct 26, 2010 12:56 PM
bnb29
Apr 17, 2006 08:47 AM
Delzell
Mar 28, 2006 11:54 AM
