what is the 'BRAIN" called?
Old Aug 12, 2009 | 04:33 PM
Copedawg's Avatar
Copedawg
I was at the junkyard today looking for an IDM. The counterguy refered to it as a computer. I tried to tell him that it controlled the Injectors but he was pretty flippen sure it was a computer. I saw something it the lDM I did a mod to that resembled a processor but I don't think it is.
If you were to dump a program in your truck, where is it stored? What is the component called?
Old Aug 12, 2009 | 04:42 PM
Action4478's Avatar
Action4478
Its called the Powertrain control module (PCM)
Old Aug 12, 2009 | 04:44 PM
Copedawg's Avatar
Copedawg
Yes! OK, I knew that way back when, thanks. Where is it located?
Old Aug 12, 2009 | 04:58 PM
79f-250custom's Avatar
79f-250custom
behind the e-brake assembly. take the 3 bolts off the e brake, then go under the hook take off the wire harness and 2 more bolts"i think" and pull it out from behind the e-brake.
Mitch
Old Aug 12, 2009 | 04:59 PM
79f-250custom
you idm is bolted onto the driverside fender with 3 8mm bolts and a 10 mill bolt that holds on the harness.
Mitch
Old Aug 12, 2009 | 05:40 PM
Action4478's Avatar
Action4478
Thanks to TJ Beggs ...
The PCM comes out from under the hood ....
Old Aug 12, 2009 | 05:58 PM
Copedawg's Avatar
Copedawg
Thanks fellas! I am on track now.
Old Aug 13, 2009 | 07:53 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
Cope,
You (we) can also use the IDM from Super Duties. These are much harder to remove than the OBS as they are further down the fender. All IDM's are interchangable between '94 - '03.
Now the SD ECM (same as our PCM) is easier to get to than the OBS, under dash, driver's side.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Aug 13, 2009 | 08:11 AM
Copedawg's Avatar
Copedawg
Are the PCM and ECM interchangeble as well?
Old Aug 13, 2009 | 08:28 AM
Brown Falcon's Avatar
Brown Falcon
The ECM from a Superduty will be set up to run split-shot injectors. So unless you have a '97 cali emissions model it won't run your injectors right.
Old Aug 13, 2009 | 08:33 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
Bingo.
The programming/tuning of the truck goes via the ECM/PCM so they are different for Splits & Singles.
The IDM's only job is to charge the solenoids of the injectors (basically), so it doesn't care if they are Split or Single shot. It just want's to know when to charge the solenoids and for how long.
FWIW, I have an actual IDM hooked to a lap-top that runs my flow bench.
__________________
Old Aug 13, 2009 | 08:41 AM
Copedawg's Avatar
Copedawg
Good deal! Actually I do have a stinky Cali model. What I am hearing is that I could use a ECM then. Will a newer ECM let me pop wheelies? would it give it more horses?
Old Aug 13, 2009 | 08:47 AM
Brown Falcon
Not sure if it'll give you any more power... probably not.
Old Aug 13, 2009 | 08:48 AM
Copedawg's Avatar
Copedawg
and if I ever change my injectors I would need to get splits?
Old Aug 13, 2009 | 09:28 AM
Brown Falcon
You would need to get a custom chip like a TW, DP Tuner, or PHP that will run the bigger single-shots. You'd have to do that anyways if you got bigger injectors though even if you did have the single-shots already.
