351 Coil wiring
Old Aug 12, 2009 | 01:59 PM
66_in_ky's Avatar
66_in_ky
351 Coil wiring
I usually hang out in the 61-66 and FE forums. I'm preparing to install a rebuilt 428 in my 66 F250. I don't have a tach installed on the truck. I do have an old Sears handheld dwell / tach that I've never used. I want to test it on another V8 and my friend has a 1990 F250 with an 351.
My understanding is that the the red clip on the tach is supposed to go on the negative side of the coil and the black clip is supposed to go to ground (negative post on the battery).
I read another post on this forum concerning a similar question on a 5.0L
https://www.ford-trucks.com/forums/3...onnection.html
The original poster there said "The stamped marks ( + /- ) were located at the bottom inside the female connector and the negative wire on mine was yellow with a dark green stripe."
Will the negative wire be the same on a 351?
Thank you
Old Aug 12, 2009 | 02:15 PM
lew52's Avatar
lew52
I don't know if it will be the same color , but the neg side of the coil is the dist side so you can follow the wire ... Lew
Old Aug 12, 2009 | 09:49 PM
66_in_ky's Avatar
66_in_ky
Lew - Thank you for the guidance. We will check it out tomorrow.
mrmotoguzii00
3.8 & 4.2L V6
Mar 17, 2018 08:04 PM
cyris426
30
Nov 23, 2014 06:25 PM
rowdyredneck
Aug 3, 2013 10:45 AM
Screamin T/A
Feb 1, 2012 09:09 PM
lakecityg
Electrical Systems/Wiring
Jun 27, 2011 08:37 AM
