Need replacement mirrors
Old Aug 11, 2009 | 11:32 PM
mpuvdd's Avatar
mpuvdd
Question Need replacement mirrors
Could anyone refer me to someone that sells the same type of mirrors pictured below? Thanks a lot.
Old Aug 12, 2009 | 11:17 AM
iggybob44's Avatar
iggybob44
those look like the mirrors used in a bunch of mid 80's Ford pickups and Broncos......ive seen a nearly identical mirror at Kragen.
Old Aug 12, 2009 | 11:58 AM
mpuvdd's Avatar
mpuvdd
Wow those are very close, though they look kind of cheap. Hard to say by the picture.
http://shop.oreillyauto.com/ProductD...goryCode=3161B
Anything else?
Old Aug 12, 2009 | 01:45 PM
iggybob44's Avatar
iggybob44
try a local wrecking yard,and you shouldnt have any trouble finding a set off an 80's Ford
Old Aug 12, 2009 | 02:13 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Because of the shape of the mirror head, these look exactly like D6TZ17696A.
If the mirror head is 5 1/4" x 8 1/4" and are the "Swing Lock" type of mirror, that's exactly what they are.
However, you are not going to be able to find one that matches, because someone has bent the bracket so the mirror head sits level.
The problem is...that this style of mirror was not available until 1973 which means it will not fit the 1967/72's door contour properly.
So...either the bracket has to be bent, or the mirror head will sit upwards at an angle.
D6TZ17696A / Fits: 1973/79 F100/350 / 1975/90 Econoline / 1978/79 Bronco.
btw: There are three other styles of these same type of mirrors used 1973/79. Some have a different shape to the head, some have round brackets.
1980/96, add another four.
fivonut
Jan 25, 2018 03:08 PM
dieselsubmariner
Oct 10, 2013 11:52 PM
joerickson
20
Feb 2, 2013 09:26 AM
f150luke89
1997 - 2003 F150
Oct 12, 2012 11:15 AM
Pokey11
Jun 4, 2008 08:10 PM
