Trouble Codes Need Help ASAP!!!
Old Aug 11, 2009 | 09:35 PM
derekmj64's Avatar
derekmj64
Here are the two codes that came up....
P1249
P0781
What should I do about these?
Old Aug 11, 2009 | 09:57 PM
Pocket's Avatar
Pocket
P0781 - 1-2 shift malfunction. Erase this code and see if it pops up again. This one can come up randomly, even with no real problem.
P1249 - Wastegate steady-state failure. Again, erase this code and see if it pops up again. If so, the wastegate solenoid might be going bad.
Old Aug 11, 2009 | 10:01 PM
derekmj64's Avatar
derekmj64
I cleared the codes and I was still having issues in 1st gear it was like it was slipping really bad so I put it into second and then to Drive...
Old Aug 12, 2009 | 09:10 AM
Pocket's Avatar
Pocket
Ok, so if you are actually feeling slippage on the 1-2 shift, then you have problems and it's not random phantom codes popping up.
