Sponsored by: Auxito
2000 f-150 a/c
Old Aug 11, 2009 | 04:46 PM
Gaffney1963's Avatar
Gaffney1963
2000 f-150 a/c
I have a 2000 F-150 that will blow good, cold air but every so often it will stop coming from the vents and instead blow from the defroster ports, and then switch back again. Unless I take the overdrive OFF. I'm guessing a vacuum problem, any ideas?
Old Aug 11, 2009 | 06:53 PM
george6488's Avatar
george6488
This is the 2009+ F-150 forum.
Old Aug 12, 2009 | 01:28 PM
Ultramagdan's Avatar
Ultramagdan
Moved to correct forum.
Old Aug 12, 2009 | 02:41 PM
LxMan1's Avatar
LxMan1
Thanks Dan.
I would check the plastic vacuum line behind the battery that goes into the fenderwell. It goes to the vacuum canister and when it breaks, vacuum to the vents will drop under acceleration and default to the defrost vents.
Oh, and welcome to the forum.
