Fuel/power issues
Old Aug 11, 2009 | 06:54 AM
mudbug04's Avatar
mudbug04
Fuel/power issues
It seems like every other month something strange goes on with my mpg's, whether up or down. I drive 54 miles to houston every morning at about 70-75 and in any given week range from 13.5 to 14.5 mpg.
I noticed now during the summer my fan pretty much stays on until i get to about 35-40 mph most of the time whether the engine is cold or warm. Does this actually take that much power from the truck? I have a ticking sound around the engine and i dont know where it is comming from... i cant see any signs of leaking deisel. my fuel mileage has gone down this week. I just changed the oil, fuel filter. I also use lucas about every other fillup. i have the grey cps (dont know if that would have anything to do with it). and finally is there any way i can just check the injectors without actually pulling them? Sometimes it acts like it has a small miss.
Thank you for any input.
Old Aug 11, 2009 | 07:00 AM
just another truck's Avatar
just another truck
Have you looked for leaks at your boots, also look for a leak on your up pipe. The last place I would suggest is the EBPS.
Ticking sound might suggest you may want to go in and retorque your rocker arms, and retorque your injectors.
As far as testing the injectors, I believe that this would be best done by doing a cyclinder contribution test. I have not done this, I am just repeating what I believe to be true here.
Old Aug 11, 2009 | 07:24 AM
mudbug04's Avatar
mudbug04
i hear the ticking every time i go through a drive thru, its not real loud i just know its there. So i guess find somewhere around here that does the contribution test and just go from there?
Old Aug 11, 2009 | 07:25 AM
just another truck
Or ask for someone around here who might have AE in your area. But do look for leaks on your boots and up pipes.
Old Aug 11, 2009 | 07:31 AM
WA.Ranger's Avatar
WA.Ranger
I'm really thinking your uppipes are starting to leak. That's how I would of described my symptons when I started to notice the dreaded "Tick, tick, tick". Crawl under your truck, and shine a light up towards the back of your motor and see if you can see any soot. If you can't get under your truck, hold a mirror at the back and start investigating for the same soot marks.
Old Aug 11, 2009 | 07:34 AM
riverrat41's Avatar
riverrat41
You may PM Roland(Mueckster) he is in the Houston area and might be able to get with ya.
I had the ticking sound and it was the up-pipe donuts leaking.Losing boost as well.
Old Aug 11, 2009 | 07:58 AM
mudbug04's Avatar
mudbug04
i hope i dont sound to stupid but what is AE?
Old Aug 11, 2009 | 08:00 AM
mudbug04's Avatar
mudbug04
o and i do have gauges that i have not installed yet even though i have had them for 2 weeks now so i dont know if im loosing boost or not. how hard is it to change out the donuts?
Does anybody know about the fan always bein on at low speeds? is it supposed to? i dont remember it always being like that but it is now that its summer time.
Old Aug 11, 2009 | 08:04 AM
agg_bagg's Avatar
agg_bagg
your fan should only come on if your motor is to hot. if it comes on more than that the fan clutch might be going out.
Old Aug 11, 2009 | 08:06 AM
WA.Ranger's Avatar
WA.Ranger
The donuts "can" be a pain. I didn't think mine were so bad, but others have run into nightmares......wait a minute, cracked y-pipe, yeah, mine were a little bit of a pain. If you have the extra money, I would tell you to INVEST in the bellowed set. No more leaks, ever. As far as the fan staying on all of the time, I don't know. It could be going bad, but usually don't they just freewheel? Is your radiator plugged up with alot of bugs and junk, causing insufficient airflow?
Old Aug 11, 2009 | 08:12 AM
mudbug04's Avatar
mudbug04
it shouldnt be.. i try to wash it out every time we take the four wheelers out because its usually real dusty. i might take it by the car wash this evenin and make sure though.. it has been doing this for months now and my fuel mileage aint lookin to bueno.
Old Aug 11, 2009 | 08:14 AM
WA.Ranger's Avatar
WA.Ranger
Don't forget to post up what you find out. You have us all curious now!
Old Aug 11, 2009 | 08:25 AM
mudbug04's Avatar
mudbug04
well what i see from other posts, replacing the donuts or installing the bellowed up pipes pretty much sucks right? im not to sure about spending that much money on new pipes though (cheap A^^) but dang if your gonna do the time anyway?
and about the fan will do, i couldnt find the posts again about ppl having problems with them but i coulda swore i saw that on here before.. hmm
Old Aug 11, 2009 | 08:32 AM
danskool's Avatar
danskool
Go Bills !
AE = AutoEnginuity.
Can get software and the connection for plugging in to scan.
Need the Ford Enhanced, add on packaged, to read our trucks.
http://www.autoenginuity.com/products.html
Old Aug 11, 2009 | 08:44 AM
shacks87's Avatar
shacks87
Auto Enginuity is a scantool for your laptop, great for trouble shooting, reading codes and perforuming onboard test on our trucks.
