Oil & Lubrication
Check engine, low oil?
Old Aug 11, 2009 | 01:12 AM
lylino's Avatar
lylino
My check engine light came on and the car was making thumping sounds up front. I was low on oil, so I addd 2 quarts. It runs ok now, but the light stayed on. Didn't reset it. Do you think that was it? My stupid low oil?
Old Aug 15, 2009 | 06:03 PM
cjben's Avatar
cjben
what kind of car? I have never had a car that tripped the check engine light when it was low on oil. Most likely the code is being thrown because a sensor needs replacing, the computer is sensing something out of tolerance. most auto parts stored will hook up a scanner and check the codes for you for free.
Old Aug 15, 2009 | 11:20 PM
Mawk's Avatar
Mawk
Oil pressure has it's own dummy light.
You need to scan for the code, and see what caused the CEL to come on.
Also, since you were low on oil, you may want to start keeping an eye on it, oil is vital, and once an engine starts burning it, it's hard to stop without some work.
Old Aug 16, 2009 | 05:12 PM
lylino's Avatar
lylino
I took the Escape in and it needed an ignition coil and spark plug. Cross your fingers that was it!!!
Losman33
Mar 22, 2016 05:38 PM
abe
26
Feb 10, 2016 02:39 AM
cocksy
Dec 27, 2014 10:48 AM
quick35th
May 9, 2013 09:04 AM
7677mess
General Automotive Discussion
Jan 26, 2005 06:17 PM
