Sponsored by: Real Truck
need help with trailer plug
Old Aug 10, 2009 | 04:21 PM
mickpowell1967's Avatar
mickpowell1967
i have a 04 f250 with a oem tow package is there a fuse under the hood for the center post for 12 volt supply to trailer
Old Aug 10, 2009 | 06:13 PM
bpounds's Avatar
bpounds
I believe there is a relay under the hood. Also note, the battery charge pin will not be hot unless the motor is running.
Old Aug 10, 2009 | 07:28 PM
mickpowell1967
yes i know it has to be running do you no where the relay is
Old Aug 10, 2009 | 07:31 PM
bayou barataria's Avatar
bayou barataria
Check your owners manual it will tell you what relay is for what it is in the big fuse box under the hood.
Old Aug 10, 2009 | 07:36 PM
dchamberlain's Avatar
dchamberlain
On a 2004, the trailer tow battery charge relay is the center most relay in the central junction block under the dash panel below the steering wheel. The fuse is #115 in the same block, 20 amp.
okwaho1650
Jan 27, 2009 08:54 AM
BENG0924
16
Oct 17, 2008 04:20 PM
GeneStoner
All Things Towing
May 7, 2005 01:57 PM
tnscrew
1997 - 2003 F150
Jan 4, 2003 09:34 PM
Colinator
Apr 22, 2002 06:54 PM
