How much lift needed?
Old Aug 10, 2009 | 11:21 AM
Brown Falcon's Avatar
Brown Falcon
Just curious as to how much you need to lift a OBS to fit 22.5" semi wheels under it...
Old Aug 10, 2009 | 01:31 PM
DAVID'S97F250HD's Avatar
DAVID'S97F250HD
i work with 22.5 semi wheels everyday, I'll take a measurement with an 11r22.5 tire on it, you can always go to a lower profile, alot will depend on tire size though. Also to take in consideration is the ride will likly be a little more rough, even less sidewall give then whats on our truck. Also, treads selection might suck a little bit too.
I would maybe consider a 19.5 inch rim, 22.5 is generally a little wider but if your lifting it..................
Old Aug 10, 2009 | 01:43 PM
Brown Falcon
I'm just curious because my friend back home has a set of 22.5 super singles.
Thought I might eventually do some custom mods on my truck once I'm out of the marine corps and back on the west coast again.
Old Aug 10, 2009 | 04:06 PM
DAVID'S97F250HD
aCTUALLY THINKING BACK YOU CAN GET them pretty thin so it would not be to bad, just dont lift your truck like the image attached.
http://images.truckinweb.com/brandpa...ront_wheel.jpg
Old Aug 10, 2009 | 04:58 PM
Brown Falcon
Wow, yeah. That's taller than I want. Then again, might just stick with my 16 inchers. Mainly a daily driver anyways...
