Motorcraft mixture screws.
Old Aug 9, 2009 | 10:23 PM
79FordBlake's Avatar
79FordBlake
Where would I be able to find mixture screws for a motorcraft carb on a 73 f100 302? I have one that is bent and need to replace it. Thanks.
Old Aug 9, 2009 | 10:48 PM
montana_highboy's Avatar
montana_highboy
To my knowledge no carb rebuild kits include the IMS's, you could easily grab a carb at the junk yard and use those.
Old Aug 9, 2009 | 10:55 PM
79FordBlake
No trucks that old with that kind of carb in the junkyards around my area. I have another motorcraft carb that came off a Bronco, the screws in it are longer.
Old Aug 9, 2009 | 11:32 PM
fmc400's Avatar
fmc400
MSEE
You'll have to find a set off another carburetor, be it a junkyard (I realize there are none in your area) or eBay. Pony Carburetors might also sell them, but I think they just set a minimum order in place.
Old Aug 10, 2009 | 12:40 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
2) C7MY9541B .. Idle Mixture Screw (Motorcraft CM749) / Obsolete
DON SANDERSON FORD in Glendale AZ has 16 = 623-842-8762.
PARTS INTERNATIONAL in Farmers Branch TX has 10 = 888-727-0418.
KINSEL L/M in Beaumont TX has 8 = 800-816-2894.
Old Aug 11, 2009 | 12:35 AM
79FordBlake
Why don't somebody still make them when there are so many of these carbs still around?
Numberdummy im gonna call one of the guys you listed. What do you think two of them will cost? The tag on the carb says D3TF NA. Below that it says A 3E 7. I want to make sure I get the right mixture screws.
Old Aug 11, 2009 | 01:56 AM
NumberDummy
The demand is slim and none because these carbs haven't been used in 35 years (since 1974).
Two of the three sources I listed have toll free numbers, so it's a free call to find out how much.
D3TF-NA = D4TZ9510AV .. 2V Carburetor (Motorcraft CA1792)
1973/79 Ford Light Truck Parts Catalog / Carburetor Parts List 95.29J
C7MY9541B .. Mixture Screws (Motorcraft CM749)
fdude64
Sep 15, 2009 05:46 PM
jody27803
1978 - 1996 Big Bronco
Aug 28, 2009 01:33 PM
VirginiaWiFinder
Dec 16, 2006 09:25 PM
dean307
Nov 24, 2006 11:36 PM
uncle jessie
Feb 1, 2004 11:03 AM
