TS chip sudden issue
Old Aug 8, 2009 | 08:40 PM
lucaslaw's Avatar
lucaslaw
Worked great for a couple weeks, today truck dies and throw check engine light when I change switch (6 position), or just dies for no reason. Transmission won't downshift. Stranded me, I unhooked batteries and waited, hooked back up and it fired up so I put it in "stock" position. I guess I'll try to return it for a new one (I know I know, but DP is not in the budget just yet). I can't think of anything else it could be, since it happens when I switch it.
Old Aug 8, 2009 | 09:54 PM
Izzy351's Avatar
Izzy351
Have you tried pulling it & reseating it in the PCM? If it comes loose, it *could* fry your PCM. With your keys out of the ignition, pull it, reseat it and the switch wire and try again...
Old Aug 8, 2009 | 10:17 PM
PaysonPSD's Avatar
PaysonPSD
What Joe said, and after you re-seat it use some duct tape to hold it in place if you never have.
Old Aug 8, 2009 | 10:47 PM
lucaslaw's Avatar
lucaslaw
Got it, I'll try that tomorrow, about to take a cross country tip so if that doesn't fix it I'll be taking the trip without it (don't want to get stranded)
