Offroad & 4x4
crossover/highsteer
Old Aug 7, 2009 | 05:46 PM
crazyredneckanyhow's Avatar
crazyredneckanyhow
crossover/highsteer
Anyone know of a place that sells crossover/highsteer arms for a balljoint 60?
Old Aug 7, 2009 | 07:49 PM
75F350's Avatar
75F350
Dynatrac has the entire knuckle. You cant just get an arm since there is no provisions to bolt them up.
Have your checkbook ready!
http://www.dynatrac.com/products_pro...rknuckles.html
Old Aug 7, 2009 | 10:13 PM
crazyredneckanyhow
Man that sucks. So any other options for steering when using a balljoint 60 in a 79 bronco?
Old Aug 8, 2009 | 12:55 AM
75F350's Avatar
75F350
Foir sure there is bubba. Just use a mid 80's tie rod, and a drag link for the 78/9 bronco with inverted "T" steering.
Works like a charm.
You may also upgrade the entire tie rod and drag link to the more common and desireable Chevvy 1 ton inverted "T" system. This will require some new tapperes in the knuckles and the pitman arm, but it will work great.
Slight drop pitman arm to help with some angles and you are golden.
You wont get a high steer set up without changing the knuckles, but even for huge rocks, I rarely see this high steer thing extremely necessary.
You can kind of make it out here.
Old Aug 10, 2009 | 09:41 AM
79n40z's Avatar
79n40z
75f350
I have a question on what all is involved in putting the TRE's on the upper side of the knuckles. I have a dana 44 and want to change over to the chebby 1 ton steering but would like to put it on the top side
Old Aug 11, 2009 | 03:25 AM
75F350's Avatar
75F350
Originally Posted by 79n40z
75f350
Interesting question. I might have to ask why this would bring an advantage? I can see how this would bring some clearance but in most cases this is so minimal that it does not justify the effort.
Ok, assume that it is reasonable, so lets look at the mechanics of it. Well, depending upon the axle, each knuckle has a tapered hole in the knuckle, (all do but some are larger than others) and the major diameter (largest) is located at the bottom of the knuckle is larger than the minor diameter of the TRE itself. This means that there will be a gap if the taper is turned the opposite direction.
In other words, unless there is some material added to the original hole, there will not be adequate material left to make a decent seat once the taper is made from the top side. The bottom will never make contact and the connection will fail.
In this case, a spherical rod end is used and a 3/4" straight hole is the smallest one can run. In many cases the larger 7/8" hole is appropriate.
F25CR5
18
May 26, 2019 10:16 AM
STGFordCrazy04
Offroad & 4x4
39
Apr 11, 2015 10:06 AM
lucas07770
Nov 25, 2013 06:27 PM
thekingofcows
Offroad & 4x4
28
Dec 24, 2012 02:49 AM
STGFordCrazy04
Offroad & 4x4
45
Dec 24, 2007 06:26 AM
