It is a 99.5 F350 with a 7.3. It starts and runs great and will keep running untill you turn it off. Once you turn the truck off it will not restart. Any sugestions?
It takes around 20 min for it to restart. I will check and see if the tach is moving. The fuel pump is running. The oil is fresh, full, and the proper weight.
