Sponsored by: Real Truck
help.help.help
Old Aug 6, 2009 | 07:53 PM
kingeightclub's Avatar
kingeightclub
help.help.help
hello all. found this site a coupl weeks ago,awsome.i have a 2003 f 250 w/the 5.4 Withe the engine on and in park runs smooth.Put in drive with foot on brake the engine misses.Also when cruising at about any speed,but not when acclerating.New plugs,fuel filter,air filter,pcv valve and clean MAF.I also unpluged each COP wile running. The engine flutterd after each unpluging witch tells me the COP's are good( i think).There is no codes and no check engine light.Been to one shop,they couldn't figure it out but said i was running 10% lean.any help would be great.thank you
Old Aug 6, 2009 | 08:49 PM
ReAX's Avatar
ReAX
Were the plug boots clean, black and crack free when you had the plugs replaced?
Have you checked the fuel pressure?
Old Aug 7, 2009 | 10:29 AM
kingeightclub
yes , the boots were also changed w/the plugs.have not checked the fuel pressure.will try today.thank you
Old Aug 12, 2009 | 11:25 AM
kingeightclub
checked the fuel presure.key on engine off 40psi.let sit five minutes 39psi.so i belive the fuel pressure is good. what to do next.i dont know
Old Aug 12, 2009 | 01:49 PM
Monster-4's Avatar
Monster-4
The missing sound like a bad COP. A misfiring COP will NOT trigger a CEL in these trucks. You need to read the Pending Codes from the PCM and it will tell you the cylinder(s) misfiring.
The lean issue sounds like a vacuum leak. The line that comes off the TB and goes to the PCV tends to crack at the elbow near the TB. If it gets bad enough you should evetually get a code. Check it out just to be safe.
Old Aug 13, 2009 | 07:09 PM
kingeightclub
thanks i will check the hose on the back of TB next
Old Aug 14, 2009 | 06:56 AM
yotazuki's Avatar
yotazuki
When i replaced plugs on my v10 i had miss turned out 1 of the new plug was bad out the box.
Old Aug 14, 2009 | 06:11 PM
ReAX's Avatar
ReAX
Yep new parts doesn't mean good parts.
