Gas Tank Replacement Question
Old Aug 6, 2009 | 11:28 AM
bulimic.cannibal's Avatar
bulimic.cannibal
Hi,
My truck hasn't had a gas tank behind the seat for years. It has two add on gas tanks under the bed, but neither one is set up for the gas gauge to work.
So I've got another 65 that I'm using for parts and it has a gas tank that I'm going to put into my "good" truck, and I'm wondering if there's anything special I need to treat the inside of the tank with before installing it. The truck it's coming from has been in a barn for years.
I also need to replace the fuel line grommet (where the fuel line goes through the floor). Dennis Carpenter has one but it's not for the right year. Any ideas on where I could pick one up?
I also have a lot of parts on the "parts truck" that I don't need and would be willing to sell or trade them. There is no engine or transmition in it, but things like Door Hinges, seat, side chrome trim, fenders, chrome bumpers, chrome grill are available among other things.
I've only posted a couple of times but the help I've gotten in these forums from the many other posts have been a life saver. Thanks to everyone who shares their knowledge here!
Thanks,
BC
Old Aug 6, 2009 | 12:10 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
In-Cab Fuel Tanks: 1961/66 F100/1100 / 1967/72 F100/750.
I do not have DC's catalog, so I don't know which grommet he's listed. The following info is from the 1957/63 & 1964/72 Ford Truck Parts Catalogs.
379628S .. Fuel Line Grommet / 5/16" I.D. / 1/2" thick / 31/32" diameter where it fits into the floor / Obsolete
Parts catalog pic shows this grommet fitting into the floor where the fuel line enters/exits the cab.
(EDIT: The grommet (380695S) used on 1973/77's in this location is not the same, according to the 1973/79 Ford Truck Parts Catalog)
BOWMAN FORD SALES in Bowman ND has 38 = 701-523-3257.
No other Ford Dealer, no obsolete parts vendor has any.
379627S .. Fuel Line Grommet / No specs available / Obsolete
Parts catalog pic shows this grommet further forward after the fuel line enters/exits the cab.
No Ford Dealer or obsolete parts vendor has any.
Old Aug 6, 2009 | 12:37 PM
daveengelson's Avatar
daveengelson
As for treating the inside of the tank there are restoration kits available thru Eastwood, or Por 15. The kits run from $40-$50 and consist of a cleaning solution, metal etch, and tank sealer. Recondition the tank on 65 some 15 years ago and used water to flush, then took some cleaning solution, sealed the openings on the tank, and sloshed the solution around, then drained and repeated the rinse. Then used mild solution of metal etch and rinsed thoroughly. Finally, set the tank in the sun and let it dry out. If u feel the tank requires the sealer, check for residue for metal particles, and pin holes, if so, suggest looking into purchasing a kit.
Old Aug 6, 2009 | 12:47 PM
NumberDummy
There's a rubberized coating available for use inside fuel tanks.
This stuff will stop the tank from leaking if it has rust pinholes.
The 17.5 gallon in-cab tank (C1TZ9002K) is the same 1961/69. However...
In 1970, Ford replaced the 1961/69 in-cab tank with the 1970 (1970/72) in-cab tank for use as a service part replacement.
Service part = sold by dealers at the parts counter.
The 1970/72 in-cab tank (DOTZ9002A) is 19 gallons and has been reproduced by BLUE OVAL TRUCK PARTS.
The only difference between the 1961/69 tank and the 1970/72 tank is one brass fitting.
Old Aug 6, 2009 | 02:11 PM
bulimic.cannibal
Thanks NumberDummy! Now Bowman Ford Sales only has 37 Fuel line grommets left.
And thanks Dave, I've ordered the gas repair kit from Eastwood. I figure I ought to be proactive and take care of the tank while I have it out and can do it easily.
BC
Old Aug 13, 2009 | 01:24 AM
knibbeone's Avatar
knibbeone
I am interested in the complete ignition switch, someone cut the wires and installed a universal switch assembly. PM me
Old Aug 14, 2009 | 03:32 PM
oldfordcoupe's Avatar
oldfordcoupe
chrome parts where are you located ???
78fordguy
38
Jul 10, 2019 06:43 AM
bobj49f2
21
Dec 20, 2016 06:52 PM
Ex-ChevyOwner
Oct 7, 2015 09:14 PM
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
Aug 8, 2014 10:54 AM
swampthang
Jun 21, 2014 04:41 PM
