Transfer Case
Old Aug 6, 2009 | 12:23 AM
FordBronco88's Avatar
FordBronco88
Transfer Case
Ok so my transfer case is stuck in 4x4 low as discussed in the big bronco forum and today i went to the junkyard, got the BW 1356 t_case i needed for my 88bronco, also has a BW 1356 t-case in it...but the t case i bought has an extended tail housing and longer output shaft... i need to take the stock tail housing and output shaft and put it on the new t-case i bought today...how do i swap the parts??do i need to take it all apart?? or can i just slip the output shaft out after i take the tail housing off??? help please!!
More Info:
https://www.ford-trucks.com/forums/8...sfer-case.html
