1978 - 1996 Big Bronco
'91 5.8 starting problem
Old Aug 5, 2009 | 09:31 PM
nv_brewer's Avatar
nv_brewer
1) turn key, fuel pump runs with fuel pressure of 38psi
2) Engine turns over till just out running the starter then immediately dies.
3) After several attempts the exhast manifiold is warm from some gas burning.
I've disconnected the TPS with no change. placed spark tester between wire and #1 plug and saw spark.
While turning engine FP stays at 38 psi.
Any ideas?
Old Aug 5, 2009 | 09:38 PM
g_k50's Avatar
g_k50
Incorrect timing, try to start it without the SPOUT connection. Check timing, check distributor cap and rotor.
Old Aug 6, 2009 | 11:20 AM
Kemicalburns's Avatar
Kemicalburns
PULL CODES. this is step 1 always.
Old Aug 6, 2009 | 11:43 AM
nv_brewer's Avatar
nv_brewer
I understand. But when there are no codes I go to plan B which is posting here.
Old Aug 6, 2009 | 06:19 PM
Kemicalburns
well then post that you tried pulling codes and there was none. this helps us help you. now you should have gotten a system pass code of 11 if you pulled the codes the right way. did you use the paper clip method shown on fordfuelinjection.com or did you buy a code reader?
Old Aug 6, 2009 | 10:33 PM
nv_brewer's Avatar
nv_brewer
Fixed.... Bad PCV value.
Tnewton12313
1983 - 2012 Ranger & B-Series
30
Aug 25, 2016 01:04 PM
Penton97F150
1997 - 2003 F150
Jun 26, 2016 10:49 PM
failsatheals
1997 - 2003 F150
Jun 21, 2016 09:03 PM
Rusty_S
General Automotive Discussion
Jun 26, 2013 11:51 AM
edsblue67
Jun 8, 2004 07:58 AM
