need advise
Old Aug 5, 2009 | 07:27 PM
Bustaduck's Avatar
Bustaduck
need advise
does ant body know on a o3 6.0 if a/c compressor goes out if it shoots metal into the condinsor
Old Aug 5, 2009 | 08:05 PM
bismic's Avatar
bismic
TSB
08-13-05 LACK OF A/C COOLING DUE TO DESICCANT MATERIAL CLOGGING THE ORIFICE TUBE
(Dessicant bag ruptures)
FORD: 2004-2005 Excursion
2004-2007 F-Super Duty, F-650, F-750
I have the complete TSB if you might need it. It is not metal clogging the system, but it is solids and it is a fairly expensive repair.
Old Aug 6, 2009 | 05:27 AM
Bustaduck's Avatar
Bustaduck
I need thanks
Old Aug 6, 2009 | 07:01 AM
bismic's Avatar
bismic
on its way
Old Aug 6, 2009 | 07:09 AM
jdadamsjr's Avatar
jdadamsjr
If you don't mind, I would like it too bismic ! thanks....
Was just about to bring it in before my 100k warranty expired to get all things done...
mine still cools, but not like it used to...
TIA, JB
Old Aug 6, 2009 | 07:34 AM
69cj's Avatar
69cj
Side note; The dessicant is in the drier and not the compressor. The drier is just before the the orifice tube in the flow of things.
Old Aug 6, 2009 | 06:02 PM
Bustaduck's Avatar
Bustaduck
thanks you guys. after I got the compressor off that was hell. pulled every thing else pulled orfice tub out and it was slam full of metal. so just replaced every thing for about $400.00 not to bad I guess? oh had to put new high pressure line it was leaking
