302 P/S bracket problems
Thanks for the help.
Pic:
http://i300.photobucket.com/albums/n...ngine302-1.jpg
EDIT: I have the short block from an 83 Grand Marquis in my truck and reused all my 77 accessory brackets so they should be same, a 302 is a 302 as far as mounting points go.
As for the donor truck, I don't remember if it had A/C or not. I don't plan on putting it in my truck. Probably should, but not going to.
http://i300.photobucket.com/albums/n...1-Photo1-2.jpg
http://i300.photobucket.com/albums/n...ngine302-6.jpg
your water pump doesn't have that bolt.
What year 302 is the water pump for?
If you are you'll have to use a late model power steering pump w/brackets. If not using serp belts you can get another water pump early model. Maybe the company you purchased the engine from will make a swap with you. Good luck!
Ford changed the P/S pumps on everything in 1978 except Econolines.
Does the pump have a plastic reservoir? If so, it will not fit the P/S mounting brackets of any 1977 or earlier Ford.
When Ford changed the pumps in 1978, not only are the P/S pump brackets 1978 and later only, but the P/S pressure hoses are also 1978 and later only.
E2: What does that refer to inre to a P/S pump bracket? Nothing. If it's E2XX-3A732 or 3C511, then it refers to 1982, but that's it. E2 could be a date code: May 1982, 1972 or?
And..since Ford updates 10's of 1000's of part numbers every
year, you CANNOT go by part number prefixes to ID what parts fit.E8TZ-1012-A .. Lug Nut. Does it fit 1988's? Yes and thru 1996, and...
1932 Ford's, and lots of stuff in between, cuz Ford replaced B-1012 with B-1012-A, COAZ-1012-A, C9AZ-1012-A, E6DZ-1012-A and finally E8TZ-1012-A!
btw: Post #2 = DOAZ3A732C fits some (and only some as there are more): 1970/79's, not 1967/69's.
Did'ja know that when Ford introduced the new downsized LTD in 1979, they changed the 302 block?
You just can't get a bracket off one 302 and expect it to fit another. Not where Ford in concerned....you can't.
I'm sorry if I'm wrong, but that is the way I understood it to be.
I have an 83 short block that had throttle body injection, a reverse flow water pump with a serpentine belt set up. I put my 77 timing cover on it, I put my 77 heads and intake on it, I put a 77 water pump on it and used all of my 77 accessory brackets with no issue.
I know you have forgotten more than I'll ever know about Fords Bill. But I think I'm right about this. If I'm not I'm sorry.
There is a thread in the 73-79 section where a guy took the A/C and power steering brackets from an 84 truck and mounted them to his 79 to use the newer A/C compressor.
There are THIRTEEN different 302 P/S Pump Adjusting Brackets (3A732), and EIGHT different 302 P/S Pump Support Brackets (3C511).
Some are 1978/79 only.
Why would Ford list all these fracatta 302 brackets if one would take the place of another?
And...until we find out what the OP got for a P/S pump (1977 or earlier? 1978 and later? Off an Econoline?), suggesting back and forth about what bracket fits what, is futile.
btw: Bronco parts are in the car parts catalogs 1966/79.
I'm simply saying if you get a water pump and all the brackets and accessories that go with that year water pump it should all bolt up to a 302 block.
I know I was not clear when I said a 302 is a 302.
Now I'm with you, we need to see what adjusting bracket he has. When he got the power steering pump I understand him to have gotten the mounting bracket from an 82.
Tiger can you post a pic of the mounting bracket and the adjusting bracket?
