One of the rollers on my slip yoke is coming apart. What is that piece actually called? There is the T and at both ends of the T are the silver roller bearings? Can I just replace that sliver roller or do I have to get an entire assembly? Any suggestions where to get the part?
Sounds to me like you need a new U-joint. That would be the case if the 'T' you are talking about is more like a cross. And the ends of the cross go into a cup. And the cup is lined with needle bearings.
Besides...the new one will be greaseable.
Does it look like this - If it does, it's called a universal joint or U-joint
Its starting to clunk shifting in the high gears and reverse. No squeaks though. I looked up u-joints online but there was no specific one for the middle u-joint that connects the slip yoke. There is either front or rear. Is the rear u-joint the same size as the middle one on the drive shaft?
