Only starts in drive
Old Aug 4, 2009 | 03:47 PM
cghstrojan08's Avatar
cghstrojan08
I got a 76 F350. It will only start in drive. I was thinking it was the neutral safety switch but I dont see one on my automatic transmission. Anyone got any ideas?
Old Aug 4, 2009 | 03:50 PM
ShamelessMT's Avatar
ShamelessMT
That's because '76 the neutral start switch is located under the dash on top of the steering column near the firewall.
See this thread from yesterday for more info. https://www.ford-trucks.com/forums/8...-for-help.html
Old Aug 4, 2009 | 03:54 PM
cghstrojan08
Awesome dude. Thanks.
Think I should replace it then if it only wants to start in drive? Or is there some kind of adjustment on it?
Old Aug 4, 2009 | 04:07 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The NSS is the same 1967/77 F100/350: C7TZ7A247A (Motorcraft SW600)
Is the problem with the switch or something else?
The switch fits on top of the steering column's mast jacket, and it's controlled by a spring steel selector lever (looks like this: --{ ) that fits thru a hole in the mast jacket, then snaps onto the shift tube.
The pointed end of this lever fits into the NSS and is notorious for snapping off.
Take a look-see at that pointer. Is it there...or not? If not...it also loses tensile strength and falls off.
Old Aug 4, 2009 | 04:43 PM
Witty73's Avatar
Witty73
My guess is if its only starting in Park, it just needs to be adjusted.
Old Aug 4, 2009 | 05:49 PM
cghstrojan08
Well I cant it to start in park so I guess I will take it apart later and give it a good look over.
Old Aug 4, 2009 | 08:51 PM
superd02's Avatar
superd02
if its starting in drive it might just need to adjusted you would want to move the switch towards the passengers side
note if your reverse lights are working in neutral also
Old Aug 4, 2009 | 08:54 PM
cghstrojan08
The reverse lights work in reverse so something isnt right.
Old Aug 4, 2009 | 08:56 PM
superd02's Avatar
superd02
yeah sounds like broken plastic
Old Aug 4, 2009 | 08:58 PM
cghstrojan08
Well I think I am gonna take it apart tomorrow and put a volt meter on it to see if it is working or not. If not, then gonna go get another one. If it does, then I dont know what to do next.
Old Aug 4, 2009 | 09:05 PM
BSCowboy's Avatar
BSCowboy
I just went through this dance with my truck. In my case, it was the piece on the steering column that contacts the neutral safety switch that broke off when I replaced the shift collar (thanks ND).
Old Aug 4, 2009 | 09:07 PM
cghstrojan08
I see the little thing sticking out of the column and it moves with the gear selector.
Old Aug 4, 2009 | 10:04 PM
NumberDummy
Uh huh, but is the pointed end still on it, or has it snapped off?
The end of that selector lever (DOTZ7B097B) resembles the end of an Arkansas Toothpick, if y'all know what that is.
Ford just obsoleted the little darlin' but there's quite a few still around at dealers, obsolete parts vendors.
For example.....
PARTS INTERNATIONAL in Farmers Branch TX has 18 = 888-727-0418.
GREEN SALES CO. in Cincinnati OH has 12 = 800-543-4959.
Old Aug 5, 2009 | 07:42 AM
cghstrojan08
Can I just take a picture of it and show you? Then you can tell me if it is broke or not?
Old Aug 5, 2009 | 08:53 AM
superd02's Avatar
superd02
sure could
