Bronco II Ford Bronco II
Fuel pump woes.
Old Aug 4, 2009 | 11:38 AM
TheRon's Avatar
TheRon
Fuel pump woes.
I just helped a buddy of mine install a new low pressure (in tank) fuel pump in his 1986 bronco because he was experiencing sputtering and backfiring at accel. we determined the in tank pump was bad.
However after replacing the pump and a few days later the reassuring hum of the new pump went away and the sputtering comes back I was just wondering if there is some kind of relay or something that could be doing this. We tested the old pump and it DID NOT work
There is probably less than 100 miles on the new pump, Could the whole sending unit have gone out? After replacing the pump the fuel gauge did not work correctly anymore. My friend is mad at me for suggesting he buy this truck and I would like to redeem myself by helping him get this thing on the road so it can be as reliable and fun as mine!
Any help greatly appreciated guys
TheRon
Old Aug 4, 2009 | 06:00 PM
mrshorty's Avatar
mrshorty
There is a relay in the fuel pump circuit, and it can fail permanently or intermittently. Any number of other ways this could fail, too.
When you, "tested the old pump and it DID NOT work" exactly how did you test it? Is the HP pump running when the LP pump isn't? Exactly what are the pump(s) doing? Do they both have power? Ground? At this point, I'd be inclined to suggest that you get a voltmeter and a wiring diagram for the fuel pump circuit and determine exactly what is going on.
Old Aug 4, 2009 | 07:01 PM
Mustang6147's Avatar
Mustang6147
Doesnt that stink!!
I can say this from my own experience.... Make sure your grounds are clean, as previously stated. A bad ground will caus the pump to pull less amps and over heat.
I can also add this. I bought 3 in a row from Autozone. On the 3rd's failure, I took it to a friends shop. He replaced it with an AC/DELCO pump. He said they are the best. I said I did that to. He showed me the pump. Ya it was in an A/C delco box, I also had the receipt, but not an A/C delco pump.
He got the district manager over to his shop, showed him. He paid for the whole repair, and a Oilchange my choice in oil.
It appears there may be a reboxing issue there. Either way, I learned my lesson and wont buy there again
Old Aug 5, 2009 | 09:55 PM
74 bronco's Avatar
74 bronco
I had a proplem on an 88 bronco 2 and it end up being the ground for the computer that went to the batter and front raidator support.
Bigbocephus
Feb 2, 2025 03:32 PM
TheRon
Bronco II
15
Sep 3, 2013 07:06 PM
TheRon
Bronco II
Jun 11, 2009 09:07 AM
TheRon
Bronco II
Feb 28, 2009 11:43 AM
TheRon
Bronco II
Sep 19, 2008 06:40 AM
