Sponsored by: Real Truck
Ram-mount
Old Aug 4, 2009 | 08:55 AM
capemayal's Avatar
capemayal
Ram-mount
2006 F350 Lariat CC SD Long Box
I have obtained the VB-108-SW1 from www.gpscity.com. I cannot install the base plate.
The passenger seat bolts angle down. Per the mount's instructions, the base should install under the seat mounts. I've even tried on top of the seat mounts.
When installed, under the seat mount,the seat mount bolt holes will not line up to accept the bolts.
When installed, on top of the seat mount, the same problem exists.
I'm perplexed, as gpscity says they have never had a problem like this before.
If any one has installed this mount successfully, please let me know how you did it.
Thanks,
Al
Old Aug 4, 2009 | 11:56 AM
DetailerDave's Avatar
DetailerDave
I have that same mount in my 99 F-250. I have the Captain's seats, and it fits perfectly under the 2 front mounting pads on the passenger seat.
I removed the 2 front bolts, pushed the seat to tip back, enough to get the mount under, and let it go back, and put the 2 bolts back in. The large holes in the mount align with the cupped part of the seat brackets to center and locate the mount. I will snap a couple of pics when I get home from work.
Old Aug 4, 2009 | 12:47 PM
Wagion's Avatar
Wagion
IS it possible they sent you the wrong piece?
Old Aug 4, 2009 | 03:34 PM
capemayal's Avatar
capemayal
Anything is possible, as far as the wrong piece.
I'm not sure about your truck, but mine - with the power seats - are on an incline (downcline) to the floor.
The base is angled for under the seat. Gpscity tech support said, when I called about the installation, that most of the f350s were done on top of the seat rail. Seems to defeat the purpose of the rail fitting inside the base's holes.
On top of the seat rails, there is no place in the base for the bolt heads to turn down onto. It's just a hole. I guess washers could do, but the bolts are too short for that installation.
If I have to modify with longer bolts and washers, then I think Ram should pay for them.
I have a Ram in my '01 International 4700 LP, and like it a lot. That's the only reason I considered this mount. It was either this or a Jotto
Thanks, Al
Old Aug 4, 2009 | 03:58 PM
DetailerDave
Not sure why there would be any difference between seat mounting for an F-350, vs an F-250, but here are a couple of pics.
Old Aug 5, 2009 | 02:29 PM
capemayal's Avatar
capemayal
Detailer - After looking at your pictures, I decided to try again. No luck.
I emailed gpscity and they're going to pick up the mount.. But I asked them if they knew of any reason why this wouldn't work. I'm still waiting for a reply.
I've attached pictures of my unit, hope this helps. Maybe you'll see something I'm missing.
Al
Old Aug 5, 2009 | 05:14 PM
DetailerDave
It does look like the correct mount. How big are the holes where the bolts go? They should be around an inch+ in diameter. Perhaps if you loosen the rear seat attaching bolts, to allow some movement for the seat itself. When I installed, I put the mount under the seat tabs, wiggled stuff around, got the bolts started, and used my impact to run the bolts in.
Old Aug 5, 2009 | 05:39 PM
capemayal's Avatar
capemayal
Thanks, Dave
I did loosen the bolts - nearly 100%. I did everything I could to get things lined up, but just couldn't.
The bolt heads are about 3/4" accross, definitely not even close to 1". In fact, I used a 3/4" wrench and it was a little too big, but did grasp enough to do the job.
Old Aug 5, 2009 | 06:35 PM
DetailerDave
I am referring to the size of the holes in the Ram Mount, not the bolt head size. Mine are #55 (?) Torx bolts, about 1" in diameter.
The holes in the mount should be about 1 1/4 inch in diameter, for the cup (where bolts are) on the seat tabs to fit into.
http://www.ram-mount.com/CatalogResu...6/Default.aspx
Old Aug 11, 2009 | 08:01 AM
capemayal's Avatar
capemayal
Thanks, Dave.
I've tried everything.
The problem is that the holes just won't line up.
I've been under the rails, over the rails.
I've used fender sashers to hold the bolt heads when putting the base over the rails.
I'm at a loss. GPSCity can't figure it out either.
Calling Ram is a joke. They just refer you back to GPSCity through their automated system.
Al
Old Aug 11, 2009 | 09:10 AM
DetailerDave
Only thing left I can think of is they sent you the wrong base, or it was made incorrectly. Measure the center to center of the seat mounting holes, and center to center of the bracket itself. Mine may be a slightly older model, as it doesnt have the big "R" in the base.
Do you have a pic of your base showing the mounting holes by itself? The pics you posted earlier make it appear like the holes are small.
Old Aug 11, 2009 | 09:43 AM
capemayal's Avatar
capemayal
Thanks, Dave.
GPSCity says it's definitely the right base.
I just think the base's arms are not angled enough. As far as the seats's rails sitting in the base's holes - that's not a problem.
When the base is under the seat it just lifts the seat rails too high, thus misaligning the bolt holes.
They said that most with my truck put the base on top. Then why do they say under - really confuses me.
But, if I could put it on top, as I tried, there needs to be some type of washer that the bolt could turn down on, plus longer bolts. That's the least I could figure. Of course it would look like hell.
I'm tired of playing with it, so it's going back. I don't know what else to do with it, short of being a wall ornament.
Thanks for your help though.
Al
Old Aug 11, 2009 | 09:48 AM
smlford's Avatar
smlford
Not trying to be a smart a$$ but why don'f you just drill out the plate holes until they are large enough for everything to line up?
Old Aug 11, 2009 | 09:56 AM
capemayal's Avatar
capemayal
I understand what you're saying, and I thought about that.
But, I don't think that should be something I need to do.
This product is just too expensive for me to fool around with it like that.
A product is either made right or not a all. IMHO.
Thanks though.
Al
Old Aug 11, 2009 | 10:19 AM
DetailerDave
The design of the mount is that it goes under the seat bracket. If it went above, the mount would be up off the floor, and look ugly, and be a hazard for passengers. I agree, if it doesnt fit correctly, they should replace the mount, or send a refund.
