wiring schematic
Old Aug 4, 2009 | 06:01 AM
30dodge's Avatar
30dodge
wiring schematic
Can anyone tell me where I might find a wiring schematic for 86 F-250 online, need to know which wires are for what on headlight switch and any other switches I need to wire up. I purchased a new harness but the details are scetchy at best and not specific to what I am doing.Thanks
Old Aug 4, 2009 | 11:03 AM
sparky's Avatar
sparky
Try autozone.com You have to register, but it is free and then you get access thru "repair info", select the truck and year and rest is self explanatory
Old Aug 4, 2009 | 01:36 PM
jaye's Avatar
jaye
If you can't find it hook up the power source to the switch and use your test light to see which post is hot during the various clicks on the switch.
Old Aug 4, 2009 | 04:53 PM
30dodge's Avatar
30dodge
Tried autozone as suggested, I did not see anything there that might be of any help, At this point I cannot hook up any power source as harness is laying on ground, I need a pin guide, it will tell me what each and every pin that is on that computer module goes to so that I can find my power sources ect. Any suggestions on where I might get this would be helpfull.
Old Aug 4, 2009 | 09:02 PM
sparky's Avatar
sparky
Ok I thought you wanted headlight switch wiring schematic??? hence Autozone suggestion which has fairly decent basic wiring diagrams....... for the ECM, aka engine control module try this link.......
http://fordfuelinjection.com/truckpinouts.html
Or am I still missing the question
Old Aug 4, 2009 | 09:08 PM
30dodge's Avatar
30dodge
That looks more like it, I can look at it more tomm getting late now but thanks alot
