electrical problem
Old Aug 3, 2009 | 11:15 PM
desert sled's Avatar
desert sled
electrical problem
Today my windows stopped working and at the same time the radio quit. All other electrical systems worked. After about 5 minutes of this, the windows and the radio began working again. this happened right after I ran into the store and resarted the truck. Any ideas?
Old Aug 4, 2009 | 07:20 PM
tracknut's Avatar
tracknut
If you find out make shur you post it my f350 did that 3=4 times and stopped allto gether good luck Ipulled the fuze box and the front halve of the wiring to see if it had bad wires. the fuze box was growing green stuff in it. cleaned it and no help. new ignition switch no help. Got mad and hot wired the fuze box still works but will run batterys down in 3 day if not driven Good luck Jeff
Old Aug 4, 2009 | 07:22 PM
just another truck's Avatar
just another truck
Tracknut, if you have green stuff in the back of your fuse box, you have a water leak, have you had your window replaced?
Old Aug 4, 2009 | 07:47 PM
tracknut's Avatar
tracknut
I found a split seam in the fire wall
