Oil & Lubrication
first oil change
Old Mar 14, 2002 | 06:58 AM
fordatlast's Avatar
fordatlast
first oil change
I have been reading on this site there were some people using different weight oils in their trucks. Just thought I would share this with you all. I brought my new truck into the Ford Dealer for its first oil change yesterday and asked them about which oil they use and recommend for the 4.2 V6. I have 2000 miles on the truck. They said that Ford recommends only the 5w30 oil not the 10w30. This is the oil tha will keep your warranty intact. I also asked them if the truck needs any grease fittings added. They said that the only grease the truck needs is in the pitman arm, which they greased. I dont even know what a pitman arm is. Just thought I would share this info with you.
2002 F150 XLT
Old Mar 16, 2002 | 02:15 PM
cmlind's Avatar
cmlind
first oil change
