408w truck engine (not a racing engine! :)
It dawned on me this morning that I'm going about this all wrong. :/
The smart thing to do (if it's possible) is to look at torque graphs
with various parts assembled and pick the graph out -then- build
an engine to match the engine that made the graph.
Heard an engine runs at it's most efficient when running at the
RPM of its peak torque.
Is that true? :)
If so... I'd like the peak to be in the 2500 to 3000 range. LOL :)
With a 4 inch stroke.
Any ideas?
Alvin in AZ
Is that true? :)
Any ideas?
Alvin in AZ
Here are three articles all on one page...
1) Torque and Horsepower - A Primer
2) Setting the Record Straight on Torque and Power
3) Plato and Socrates Discuss Torque, Power and Acceleration
http://www.vettenet.org/torquehp.html
Re-read that after starting this thread about the 408w "truck engine". :)
I still want my 408w to have its peak torque between 2500 and 3000.
'91 Bronco + ZF is going to be turning 2500 rpm at 80mph.
High lift, short duration cam with short rods and a 4 inch stroke kinda
like a 300-I6 with two extra cylinders.
Is that too much to ask? :)
Alvin in AZ
Alvin in AZ
Cool. :)
Sounds like the perfect spot for my build! :)
I see that information as... the factory knew what rpm the engine
was going to be generally used at and designed for that rpm.
How do you see it? :)
Alvin in AZ
Alvin in AZ
Alvin in AZ
Alvin in AZ
on
Matching components
I notice that the carburetion in those graphs is 800 CFM and 1000 CFM respectively. That's not appropriate for the low rpm Alvin specified. How about graphs with 600 or 500 CFM more in keeping with a 3000 rpm rev limit?
It's a question of matching components. Presumably a huge carburetor and aftermarket cam will work better with higher flow heads.
dimora
176
04-26-2018 08:00 PM
Rusty_S
44
05-18-2010 10:23 PM
CowboyFromHell
04-22-2009 11:08 PM
