Coolant Fan ??'s
I noticed yesterday after comming home from a 40 or so mile trip towing the boat that the fan had come on for a bit. I am not towing a huge boat here its a 19' probably weighs in at 4k with the trailer and full of fuel.
The situation:
The fan hadnt come on at all while toing either on the way or or the way home. I stopped after towing, mostly 45mph with occassional 30 & 55 mph zones, at the local sandwhich shop and left the truck running with the wife and pup in the truck for maybe 7-10 minuites. When I pulled away the fan came on for maybe 500 feet or so and then shut off. It was about 80-85* or so. I am hoping that you guys will tell me this is normal and not to worry.
I am not loosing coolant, I dont smell coolant, and the truck never pukes (Knock on Wood). I hope this isnt bad karma for me starting that darn haapy thread last week.
Anway I took the truck for a short ride early last week to pick up some parts for a job and it did the same thing too. It was 85-90* with high humididty when it happened.
Hopefully all is well with the truck.
One last question, now that I am paranoid I am going to buy a coolant guage, where should the sensor go to and at what temps should the truck run, and when should I worry. I know the truck will defuel but I would like to prevent it if I could.
Sarge
Sarge
Have you looked at the DashDAQ? It's pretty expensive but will monitor almost anything that is available via the OBDII port. You can also program alarm setpoints for critical parameters.
Sarge
Last edited by texans; Aug 3, 2009 at 04:06 PM. Reason: to add this...truck should stay around 190 to 200 for the most part. I wouldnt worry unless it gets over 220
I have an EDGE insight, and I can tell you after my last trip that without it I probably would have come close to frying something. Personally, I would never have regular gauges.
During the summer here in Vegas, once the outside temp hits 85 deg, the fan will come on and off during the day, at very weird times, not seemingly related to engine temp. (Unloaded city driving) It will often still be engaged first thing in the morning, it will run for awhile and then cut off. There seems to be no "one size fits all" answer to when & why it comes on. This does make sense though, as the fan is not simply controlled by coolant temp alone.
Now towing is a different matter. On the open road the fan engages at 210 degrees, not fully engaged, just partially. As the coolant temp climbs, the fan engages more, until 213 - 214 degrees when it is fully engaged and will remain so until the coolant temp is back to 203 or less (sometimes all the way down to 195). On my truck it has been quite common for the fan to cycle on and off frequently. I know this because I just got back from a 2,400 round trip pulling a heavy trailer all the way.
Another observation is that if you can keep the truck in a top gear, the EGT temps will be high (mine topped out around 1,120) but the oil and coolant temps will climb very slowly. If the truck kicks down one or two gears, the EGT will be alot lower (around 950 or so) but the oil and coolant temps climb very rapidly. This is very interesting to me because the belief has always been that these engines love to rev over 2,000 rpms. From what I have observed, not so much. If I had to continue to tow heavy loads, I would definately be getting a stick.
Now bear in mind that this is how my truck runs, from what I have read on here, it seems that hey all run differently, some a litlle, some a lot.
I would not be at all worried that you have a problem, but do get gauges becasue my stock gauges didnt move at all, even when the coolant temp hit 220 and the trans hit 200.
x2 mine runs just like this here in So Cal
climbing long grades towing what have you seen your temps max?
my oil around around 240 coolent 230 trans 200 egt 1250...I saw these on the hwy395 from bishop to mammoth during 105deg outside temp about 45-50mph up the steep grade towing my 26' toyhauler...on the flats runnning 60-65mph it was coming on and off every few minutes and the temps were going up and down...oil was between 215-230 coolent was 205-220.
is it better to run in a lower gear and have cooler egts and faster moving oil and coolent temps or better to run in top gear and have the egts higher and the oil and coolent temps moving slower??
Normally the fan will not come on unloaded unless I am in stop and go traffic and the A/C is on max cool. Towing the boat like I said it only came on after the truck sat and idled for about 10 minuites with the A/C on max cool and high ambient temps ith 100% humidity.
The route to get me to the lake does include some steep grades so I wouldnt be concerned if the fan came on.
Also when it did come on it ran for a short time, 500' or so, and not at full power.
Sarge
