nonford 12v conversion help
Old Aug 2, 2009 | 10:56 AM
yonu's Avatar
yonu
like it says I am in need of a little help and i figure this should be fairly universal I have a friend that has a 46 Chrysler that they had a new engine and the electrical system upgraded from 6v to 12v how there fuel gauge stops at half a tank i know the stock guage needs an adapter bo drop the sender voltage back to the 6v range but I am at aloss of what parts to get to build it.
thanks,
yonu
Old Aug 3, 2009 | 06:26 PM
COMPLIT1107's Avatar
COMPLIT1107
Look on eBay. (Auto Parts). There are a number of guys selling 12v to 6v drop down voltage resistor units. Just make sure you match the amps to the resistor. (Like don't put a light bulb resistor on a heater fan!)
Old Aug 3, 2009 | 08:10 PM
yonu's Avatar
yonu
lol thanks and no the only thing getting changed back to 6v is the horns and guages everything else has been upgraded to 12v
It kinda makes me a bit pissed as they put a Chevy 350 in it but what can you do but give advice
Old Aug 4, 2009 | 08:12 AM
COMPLIT1107
Maybe I misunderstood. But anyway, these Voltage drop resistors are designed for an individual circuit, such as one gauge or one light (or light group).
Old Aug 4, 2009 | 09:09 AM
yonu's Avatar
yonu
yes i know they are i was just saying that the only thing left 6v is the gauges and the horns
Old Aug 4, 2009 | 11:44 AM
COMPLIT1107
So I did misunderstand, not the first time, or THE LAST!
Old Aug 4, 2009 | 11:51 AM
yonu's Avatar
yonu
question should these work i ask because i have some on hand from another project
http://search.digikey.com/scripts/Dk...5-ND&x=18&y=26
Old Aug 4, 2009 | 12:40 PM
COMPLIT1107
The TO-220 pkg. with a heatsink is way to light. Here are some pics on a light and medium 12 to 6 drop vehicle resistor.
These do throw off a little heat, when in use because the have to "waste" the voltage to somewhere. There is even a bigger one (which looks like a coil resistor) for heater fans.
(P.S. Notice the second is rated at 50 watts, which would do comfortably one headlight, or 4-5 small bulbs, or 3-4 gauges)
Try pumping 12v to the horn, it may sound a little different, but should work. At least I haven't blown my '47 horn yet!
Old Aug 4, 2009 | 12:52 PM
yonu's Avatar
yonu
yikes i figured for the fuel gague 1.5amp was enough damn guess i will have them order one of the ones from ebay
